Python render setting commands are incorrect in the Info view #49343
Closed
opened 2016-09-13 21:26:18 +02:00 by Justin Jensen · 8 comments
This applies to at least 2.77a and 2.78rc1
When I change certain render settings using the GUI, the Python command for that render setting shows up in the Info area. However, when I open up a console and try to duplicate these commands, I get the following error:
File "<blender_console>", line 1, in <module>
AttributeError: 'Scene' object has no attribute 'file_format'
I haven't done a thorough search for this mismatch, but it's incorrect for the following settings:
bpy.context.scene.file_format
bpy.context.scene.color_depth
bpy.context.scene.color_mode
bpy.context.scene.exr_codec
bpy.context.scene.compression
bpy.context.scene.use_preview
bpy.context.scene.use_zbuffer
Thanks to this stackexchange post , I was able to figure out that the settings actually live in
bpy.context.scene.render.image_settings
This applies to at least 2.77a and 2.78rc1 When I change certain render settings using the GUI, the Python command for that render setting shows up in the Info area. However, when I open up a console and try to duplicate these commands, I get the following error: ``` Traceback (most recent call last): File "<blender_console>", line 1, in <module> AttributeError: 'Scene' object has no attribute 'file_format' ``` I haven't done a thorough search for this mismatch, but it's incorrect for the following settings: bpy.context.scene.file_format bpy.context.scene.color_depth bpy.context.scene.color_mode bpy.context.scene.exr_codec bpy.context.scene.compression bpy.context.scene.use_preview bpy.context.scene.use_zbuffer Thanks to [this stackexchange post ](http://blender.stackexchange.com/a/3062/1170), I was able to figure out that the settings actually live in ``` bpy.context.scene.render.image_settings
Author
Author
Added subscriber: @JustinJensen
Philipp Oeser self-assigned this 2016-09-14 07:40:40 +02:00
Added subscriber: @mont29
Note that our code to guess full RNA path is not always working fully… should output a ... in path then, though, to indicate it could not fully resolve it.
Member
ImageFormatSettings were not setting their rna struct path, so a possible fix here D2228: possible fix for #49343
ImageFormatSettings were not setting their rna struct path, so a possible fix here [D2228: possible fix for #49343](https://archive.blender.org/developer/D2228)
Author
Yeah, I noticed that the tooltips put the '...' in there. However, as this screenshot shows, the Info area doesn't do the '...', so it leads me to believe that the settings are found in bpy.context.scene instead of bpy.context.scene.render.image_settings
> In #49343#391647, @mont29 wrote: > Note that our code to guess full RNA path is not always working fully… should output a ... in path then, though, to indicate it could not fully resolve it. ![info_bug_screenshot.png](https://archive.blender.org/developer/F360005/info_bug_screenshot.png) Yeah, I noticed that the tooltips put the '...' in there. However, as this screenshot shows, the Info area doesn't do the '...', so it leads me to believe that the settings are found in bpy.context.scene instead of bpy.context.scene.render.image_settings
This issue was referenced by blender/blender@f64aa4e0af
This issue was referenced by blender/blender@f64aa4e0afc71ccadc3fb0faea090a1f42cd7b35
Reference: blender/blender-addons#49343
