Using render border with real-time viewport Blender Internal rendering and DrawPixels Images Draw Method results in the wrong area being rendered #49429
Closed
opened 2016-09-22 18:53:56 +02:00 by Forest Katsch · 13 comments
Blender version 2.78rc2, but this is in 2.77 as well as a week-old git master.
OS: Arch Linux.
The same bug is present on an nVidia card with the proprietary 340 driver (it's a GTX 285, and nVidia's 340xx driver is the latest supported driver for the card) as well as Intel integrated graphics. I'm 90% sure this is a Blender bug, anyway.
When using border render in conjunction with real-time viewport rendering and DrawPixels (as opposed to 2D texture or GLSL), the x-y offset of the render border is at the lower left corner of the 3D view.
To reproduce:
(You need to have Images Draw Method in settings set to DrawPixels.)
  1. Set Blender Internal as the renderer.
  2. Make sure there's something visible in your scene; having a non-transparent world background is enough.
  3. Set a render border with Ctrl-B; make sure it doesn't reach the lower-left corner.
  4. Press Shift-Z to enable render preview.
I've also attached a test case file; all you have to do is open it and press Shift-Z.
testcase.blend
Blender version 2.78rc2, but this is in 2.77 as well as a week-old git master. OS: Arch Linux. The same bug is present on an nVidia card with the proprietary 340 driver (it's a GTX 285, and nVidia's 340xx driver is the latest supported driver for the card) as well as Intel integrated graphics. I'm 90% sure this is a Blender bug, anyway. When using border render in conjunction with real-time viewport rendering and DrawPixels (as opposed to 2D texture or GLSL), the x-y offset of the render border is at the lower left corner of the 3D view. To reproduce: (You need to have Images Draw Method in settings set to DrawPixels.) 1. Set Blender Internal as the renderer. 2. Make sure there's something visible in your scene; having a non-transparent world background is enough. 3. Set a render border with Ctrl-B; make sure it doesn't reach the lower-left corner. 4. Press Shift-Z to enable render preview. I've also attached a test case file; all you have to do is open it and press Shift-Z. [testcase.blend](https://archive.blender.org/developer/F366306/testcase.blend) ![screenshot.png](https://archive.blender.org/developer/F366304/screenshot.png)
Author
Author
Added subscriber: @forestkatsch
Member
Added subscriber: @Ton
Member
No error for me (2.77a release)
Forest Katsch changed title from Using Blender Internal render border with real-time rendering results in the wrong area being rendered to Using render border with real-time viewport Blender Internal rendering and DrawPixels Images Draw Method results in the wrong area being rendered 2016-09-22 20:24:22 +02:00
Added subscriber: @YAFU
I can reproduce the problem if 'File > User Preferences > System > Images Draw Method > DrawPixels' is selected, in Blender 2.77a ( abf6f08 ) and blender from buildbot 2.78 ( 21e9db9 ).
Kubuntu Linux 14.04 64 bits, GTX 960 (370.28)
I can reproduce the problem if 'File > User Preferences > System > Images Draw Method > DrawPixels' is selected, in Blender 2.77a ( abf6f08 ) and blender from buildbot 2.78 ( 21e9db9 ). Kubuntu Linux 14.04 64 bits, GTX 960 (370.28)
Member
Member
This seems to do the trick:
diff --git a/source/blender/editors/screen/glutil.c b/source/blender/editors/screen/glutil.c
index 93bac3f..79e9e3d 100644
--- a/source/blender/editors/screen/glutil.c
+++ b/source/blender/editors/screen/glutil.c
@@ -582,11 +582,10 @@ void glaDrawPixelsSafe(float x, float y, int img_w, int img_h, int row_w, int fo
         * covers the entire screen).
        glGetFloatv(GL_SCISSOR_BOX, scissor);
-       draw_w = min_ii(img_w - off_x, ceil((scissor[2] - rast_x) / xzoom));
-       draw_h = min_ii(img_h - off_y, ceil((scissor[3] - rast_y) / yzoom));
+       draw_w = min_ii(img_w - off_x, ceil(scissor[2] / xzoom) + 1.0f);
+       draw_h = min_ii(img_h - off_y, ceil(scissor[3] / yzoom) + 1.0f);
        if (draw_w > 0 && draw_h > 0) {
                int bound_options;
                GPU_BASIC_SHADER_DISABLE_AND_STORE(bound_options);
Don't see why rast_x/y should be subtracted from scissor values, to me this would only make sense if scissor- [x]/- [x] were the max coords, but they are width/height. Added the + 1.0f to fix flickering in zoomed in images (with DrawPixels, open image in clip editor, zoom in really close).
Couldn't find any breakage but would still prefer a second pair of eyes to confirm before committing.
This seems to do the trick: ``` diff --git a/source/blender/editors/screen/glutil.c b/source/blender/editors/screen/glutil.c index 93bac3f..79e9e3d 100644 --- a/source/blender/editors/screen/glutil.c +++ b/source/blender/editors/screen/glutil.c @@ -582,11 +582,10 @@ void glaDrawPixelsSafe(float x, float y, int img_w, int img_h, int row_w, int fo * covers the entire screen). */ glGetFloatv(GL_SCISSOR_BOX, scissor); - draw_w = min_ii(img_w - off_x, ceil((scissor[2] - rast_x) / xzoom)); - draw_h = min_ii(img_h - off_y, ceil((scissor[3] - rast_y) / yzoom)); + draw_w = min_ii(img_w - off_x, ceil(scissor[2] / xzoom) + 1.0f); + draw_h = min_ii(img_h - off_y, ceil(scissor[3] / yzoom) + 1.0f); if (draw_w > 0 && draw_h > 0) { - int bound_options; GPU_BASIC_SHADER_DISABLE_AND_STORE(bound_options); ``` Don't see why rast_x/y should be subtracted from scissor values, to me this would only make sense if scissor- [x]/- [x] were the max coords, but they are width/height. Added the `+ 1.0f` to fix flickering in zoomed in images (with DrawPixels, open image in clip editor, zoom in really close). Couldn't find any breakage but would still prefer a second pair of eyes to confirm before committing.
Added subscriber: @brecht
Subtracting rast_x/y make sense if you want to clip away the right/top part of the image that's outside the scissor box. Since the purpose of this code is to clamp the width/height to some reasonable value to work around a driver bug, the proposed fix should work fine even it we loose that exact clipping.
I think the mistake in the original code is assuming that rast_x/y are relative to GL_SCISSOR_BOX coordinates, while they are actually relative to GL_VIEWPORT coordinates. In other cases where this function is used (image editor) these coordinates are always the same, but here with border render the scissor box is a subset of the viewport. So an alternative fix would be to use GL_VIEWPORT coordinates instead of GL_SCISSOR_BOX.
Subtracting rast_x/y make sense if you want to clip away the right/top part of the image that's outside the scissor box. Since the purpose of this code is to clamp the width/height to some reasonable value to work around a driver bug, the proposed fix should work fine even it we loose that exact clipping. I think the mistake in the original code is assuming that rast_x/y are relative to `GL_SCISSOR_BOX` coordinates, while they are actually relative to `GL_VIEWPORT` coordinates. In other cases where this function is used (image editor) these coordinates are always the same, but here with border render the scissor box is a subset of the viewport. So an alternative fix would be to use `GL_VIEWPORT` coordinates instead of `GL_SCISSOR_BOX`.
Author
I can confirm that @JulianEisel's fix works properly for me.
This issue was referenced by 6fc7521ade
This issue was referenced by 6fc7521adeec11fa9e68f77a30924d5ff05819a4
6 Participants
Reference: blender/blender#49429
