"Make duplicates real" on dupliverts doesn't keep hierarchy #49718
Closed
opened 2016-10-15 02:59:25 +02:00 by ChameleonScales · 13 comments
The children (spheres) get all parented to only one parent (empty) instead of being each parented to their associated empty.
Blender 2.78 Linux
- Open this blend file : [Dupliverts hierarchy.blend](https://archive.blender.org/developer/F378555/Dupliverts_hierarchy.blend) - Click on Object > Apply > Make duplicates real - Enable "Keep hierarchy" The children (spheres) get all parented to only one parent (empty) instead of being each parented to their associated empty. Blender 2.78 Linux
Added subscriber: @ChameleonScales
Member
Added subscriber: @LucaRood-3
Luca Rood self-assigned this 2016-11-20 02:45:57 +01:00
Member
Only the first dupli instance of each object is being stored in parent_gh, as they are all treated as the same hash key.
Will fix it by adding vertex index to the GHash computation.
Only the first dupli instance of each object is being stored in `parent_gh`, as they are all treated as the same hash key. Will fix it by adding vertex index to the `GHash` computation.
This issue was referenced by 99c5c8befc
This issue was referenced by 99c5c8befcfc319a4700384ff41e69bda1c66625
Member
Thanks a lot. I just grabbed a daily build but the fix wasn't there yet apparently. When should I expect to find it ?
Member
The fix is in the daily builds. You can always check what is in the daily builds, by taking the build hash, and matching it against the commits here: https://developer.blender.org/diffusion/B/history/master/
All commits up to and including the one with the hash in the build, are included.
Are you sure you are not accidentally running the wrong Blender executable? You can check by looking if the hash on the splash screen matches the hash in the filename of the archive you downloaded.
The fix is in the daily builds. You can always check what is in the daily builds, by taking the build hash, and matching it against the commits here: https://developer.blender.org/diffusion/B/history/master/ All commits up to and including the one with the hash in the build, are included. Are you sure you are not accidentally running the wrong Blender executable? You can check by looking if the hash on the splash screen matches the hash in the filename of the archive you downloaded.
Woops, I forgot to check "Keep hierarchy"...
You rock, man ! Thanks a lot for this fix.
And thanks for this last tip.
Woops, I forgot to check "Keep hierarchy"... You rock, man ! Thanks a lot for this fix. And thanks for this last tip.
Why is this bug fix neither in the a nor the b release ?
and still not in c
and still not in c
Member
It isn't in 'a' because it was committed after that release.
It isn't in 'b' because that only included performance improvements.
It isn't in 'c' because that was only to fix regressions caused by 'b'.
All changes to master (including this fix) will be released as expected in 2.79
It isn't in 'a' because it was committed after that release. It isn't in 'b' because that only included performance improvements. It isn't in 'c' because that was only to fix regressions caused by 'b'. All changes to master (including this fix) will be released as expected in 2.79
ok thanks !
ok thanks !
Reference: blender/blender#49718
