Can't set influence of NLAStrip using Python #49816
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
Reference: blender/blender-addons#49816
Hello!
Summary of problem: When I try to set keyframe for influence parameter of NLAStrip via Python code, it doesn't works as expected.
Below I will try to describe the problem in detail.
Here is my sample file - bugreport.blend
I have a cube with two NLA strips. Top strip named "CubeAction" have Animated influence turned on.
Now, I am changing its influence to 0.2. It works. In Dope Sheet I can see a keyframe created for "Influence", right under the "NLA Strip controls" group (this is because I have "Automatic keyframe insertion" turned on).
I am trying to playback animation - the influence works fine.
Now, I am reloading the file (discarding all changes) and trying to do the same with the following Python code:
My goal is to add keyframe to influence parameter of NLA strip.
I am choosing "Text" >"Run Script" in text editor area.
After that result is the following:
You can see the keyframe is added successfully, but it is on different track, outside of "NLA Strip controls" group. If I am trying to playback animation and influence doesn't applied at all - it is treated as if influence is zero
What am I doing wrong?
Added subscriber: @zelgadis
P.S. I am using Blender 2.78 binary build on Linux 64bit from official Blender website.
Added subscriber: @JoshuaLeung
Ack! Looks like I forgot to force the keyframe_insert() method in the PyAPI to add these keys to the NLA Strip instead of into the action as per normal.
https://wiki.blender.org/index.php/Dev:Ref/Release_Notes/2.75/Animation#NLA_Strips_-_Local_Keyframes_for_Time_and_Influence_Controls
This issue was referenced by blender/blender@3cbe95f683
