Blender crashes -> Append Group incl. Object using boolean modifier #49903
Closed
opened 2016-11-01 18:29:51 +01:00 by Dietmar Nelles · 13 comments
OS: Windows 10 (64 Bit)
CPU: Intel i5-2500 3.30GHz
GFX: nVidea GeForce GTX 650 Ti
RAM: 8 GB
Blender 2.78a (2016-10-24 12:20 / Hash: e8299c8)
Appending a Group (3 Objects) with boolean modifier crashes Blender
  • Create new File in Blender
  • Delete all Objects
  • Create Cube, Cylinder, Cone
  • Add all (Cube, Cylinder, Cone) to a new Group
  • Cylinder: Relations -> Parent -> Cube
  • Cube: Add Modifier Boolean (Operation: Difference / Objekt: Cylinder)
  • Save as TMP01.blend
  • Create new Blend-File
  • Append Group from File TMP01.blend
  • Blender crashes
**System Information** OS: Windows 10 (64 Bit) CPU: Intel i5-2500 3.30GHz GFX: nVidea GeForce GTX 650 Ti RAM: 8 GB **Blender Version** Blender 2.78a (2016-10-24 12:20 / Hash: e8299c8) **Short description of error** Appending a Group (3 Objects) with boolean modifier crashes Blender **Exact steps for others to reproduce the error** - Create new File in Blender - Delete all Objects - Create Cube, Cylinder, Cone - Add all (Cube, Cylinder, Cone) to a new Group - Cylinder: Relations -> Parent -> Cube - Cube: Add Modifier Boolean (Operation: Difference / Objekt: Cylinder) - Save as TMP01.blend - Create new Blend-File - Delete all Objects - Append Group from File TMP01.blend - Blender crashes
Author
Author
Added subscriber: @madOS
Dietmar Nelles changed title from Append Group incl. Object using boolean modifier to Blender crashes -> Append Group incl. Object using boolean modifier 2016-11-01 18:40:00 +01:00
Member
Added subscriber: @Blendify
Member
Everything worked when I tried. Please:
Everything worked when I tried. Please: - Test with a version of Blender from https://builder.blender.org/download/ - Upload the file with the group that crashes so we can try to reproduce with that
Author
Hi,
it's still the same.
Blender 2.78
Date: 2016-11-03 02:15
Hash: f800794
Please create a new Blender file and delete all objects.
Try to append (Shift F1) the Group "Group" from the uploaded File "TMP01.blend" TMP01.blend (created with Hash: f800794)
Hi, it's still the same. Blender 2.78 Date: 2016-11-03 02:15 Hash: f800794 Please create a new Blender file and delete all objects. Try to append (Shift F1) the Group "Group" from the uploaded File "TMP01.blend" [TMP01.blend](https://archive.blender.org/developer/F392344/TMP01.blend) (created with Hash: f800794) ![BlenderError.JPG](https://archive.blender.org/developer/F392345/BlenderError.JPG)
Member
Ok I can confirm that it crashes with the file you gave
Bastien Montagne was assigned by Aaron Carlisle 2016-11-03 19:51:43 +01:00
Member
19: BLI_system_backtrace - 0x316869B0
18: id_us_clear_real - 0x30EACB10
17: libblock_remap_data - 0x30EC21D0
16: BKE_libblock_remap_locked - 0x30EC0A90
15: BKE_libblock_unlink - 0x30EC1050
14: BKE_library_make_local - 0x30EAF9D0
13: wm_link_append_exec - 0x2FE8FF00
12: wm_handler_fileselect_do - 0x2FE69A40
11: wm_handler_fileselect_call - 0x2FE6A010
10: wm_handlers_do_intern - 0x2FE6A2B0
9: wm_handlers_do - 0x2FE6A940
8: wm_event_do_handlers - 0x2FE64FD0
7: WM_main - 0x2FE47FB0
6: main - 0x2FE40AA0
5: invoke_main - 0x35F369D0
4: __scrt_common_main_seh - 0x35F36780
3: __scrt_common_main - 0x35F36760
2: mainCRTStartup - 0x35F36A20
1: BaseThreadInitThunk - 0xE29D8350
0: RtlUserThreadStart - 0xE40F5E70
BLI_assert failed: C:\Users\Aaron\BlenderDev\blender-git\blender\source\blender\blenkernel\intern\library.c:190, id_us_clear_real(), at 'id->us >= ((((ID *)id)->flag & LIB_FAKEUSER) ? 1 : 0)'
18: BKE_idcode_to_index - 0x30F1AA80
17: DAG_id_type_tag - 0x30E3DDC0
16: BKE_libblock_free_ex - 0x30EC0120
15: BKE_libblock_free - 0x30EC00D0
BLI_assert failed: C:\Users\Aaron\BlenderDev\blender-git\blender\source\blender\blenkernel\intern\idcode.c:308, BKE_idcode_to_index(), at '0'
Error: EXCEPTION_ACCESS_VIOLATION
``` 19: BLI_system_backtrace - 0x316869B0 18: id_us_clear_real - 0x30EACB10 17: libblock_remap_data - 0x30EC21D0 16: BKE_libblock_remap_locked - 0x30EC0A90 15: BKE_libblock_unlink - 0x30EC1050 14: BKE_library_make_local - 0x30EAF9D0 13: wm_link_append_exec - 0x2FE8FF00 12: wm_handler_fileselect_do - 0x2FE69A40 11: wm_handler_fileselect_call - 0x2FE6A010 10: wm_handlers_do_intern - 0x2FE6A2B0 9: wm_handlers_do - 0x2FE6A940 8: wm_event_do_handlers - 0x2FE64FD0 7: WM_main - 0x2FE47FB0 6: main - 0x2FE40AA0 5: invoke_main - 0x35F369D0 4: __scrt_common_main_seh - 0x35F36780 3: __scrt_common_main - 0x35F36760 2: mainCRTStartup - 0x35F36A20 1: BaseThreadInitThunk - 0xE29D8350 0: RtlUserThreadStart - 0xE40F5E70 BLI_assert failed: C:\Users\Aaron\BlenderDev\blender-git\blender\source\blender\blenkernel\intern\library.c:190, id_us_clear_real(), at 'id->us >= ((((ID *)id)->flag & LIB_FAKEUSER) ? 1 : 0)' 19: BLI_system_backtrace - 0x316869B0 18: BKE_idcode_to_index - 0x30F1AA80 17: DAG_id_type_tag - 0x30E3DDC0 16: BKE_libblock_free_ex - 0x30EC0120 15: BKE_libblock_free - 0x30EC00D0 14: BKE_library_make_local - 0x30EAF9D0 13: wm_link_append_exec - 0x2FE8FF00 12: wm_handler_fileselect_do - 0x2FE69A40 11: wm_handler_fileselect_call - 0x2FE6A010 10: wm_handlers_do_intern - 0x2FE6A2B0 9: wm_handlers_do - 0x2FE6A940 8: wm_event_do_handlers - 0x2FE64FD0 7: WM_main - 0x2FE47FB0 6: main - 0x2FE40AA0 5: invoke_main - 0x35F369D0 4: __scrt_common_main_seh - 0x35F36780 3: __scrt_common_main - 0x35F36760 2: mainCRTStartup - 0x35F36A20 1: BaseThreadInitThunk - 0xE29D8350 0: RtlUserThreadStart - 0xE40F5E70 BLI_assert failed: C:\Users\Aaron\BlenderDev\blender-git\blender\source\blender\blenkernel\intern\idcode.c:308, BKE_idcode_to_index(), at '0' Error: EXCEPTION_ACCESS_VIOLATION ```
This issue was referenced by 4a68ff150f
This issue was referenced by 4a68ff150f47bfeb4d4252473b2b906d14f091c5
Author
Changed status from 'Resolved' to: 'Open'
Author
RAM: 8 GB
version: 2.78 (sub 0), branch: master, commit date: 2017-02-08 13:50, hash: 3c04373, type:
build date: Wed 02/08/2017, 07:45 AM
Hi,
The bug is back in Blender 2.78.b
I've created a new TMP02.blend file TMP02.blend using Blender 2.78b.
Please try to append the group 'group' (from TMP02.blend) in an empty new blend-file. On my system the blender task disapears immediately without any message box.
System Information OS: Windows 10 (64 Bit) CPU: Intel i5-2500 3.30GHz GFX: nVidea GeForce GTX 650 Ti RAM: 8 GB Blender Version version: 2.78 (sub 0), branch: master, commit date: 2017-02-08 13:50, hash: 3c04373, type: build date: Wed 02/08/2017, 07:45 AM Hi, The bug is back in Blender 2.78.b I've created a new TMP02.blend file [TMP02.blend](https://archive.blender.org/developer/F487160/TMP02.blend) using Blender 2.78b. Please try to append the group 'group' (from TMP02.blend) in an empty new blend-file. On my system the blender task disapears immediately without any message box.
sight 2.78b is not a bugfix release, it is a performances release (mostly for Cycles improvements). Wait for 2.79.
*sight* 2.78b is not a bugfix release, it is a performances release (mostly for Cycles improvements). Wait for 2.79.
Reference: blender/blender#49903
