Cycles- MIS gives better result with resolution superior to input HDRi's resolution #49952
Reference: blender/blender#49952
All
Broken: 2.78a
Using a resolution of MIS superior to the input image gives better results. The quality should improve up to image resolution and then stay constant.
Open attached .blend. Included is an HDRi from Greg Zaal under CC-BY with a resolution of 512x256 : bug mis hdr.blend
Render animation:
frame 1 is at 512 for MIS (should be the best result already)
frame 2 is at 1024 = 4x more pixels, interpolated
Frame 3 at 2048 = 16x more pixels, interpolated
Added subscriber: @bliblubli
Added subscribers: @brecht, @LukasStockner, @Sergey
Ah, yes, I wanted to look into that.
But, I think you forgot to attach the .blend?
True :D
bug mis hdr.blend
Yes, I can reproduce the issue, and it should not behave like that.
Interestingly, my first assumption was that it's due to the texture interpolation - but, when switching to closest, the difference is much higher, which makes me suspect an off-by-one bug somewhere in the sampling.
This issue was referenced by blender/cycles@512a999023
f89fbf580e
Okay, should work now.
To give an example how bad this bug could be:
Old code, 256spp, Closest Interpolation, Resolution 512:
New code, 8spp, Closest Interpolation, Resolution 512:
Regarding linear interpolation: That needs twice the image resolution right now to look good - it could be improved, but that would probably make Closest interpolation worse. Still, I guess that linear interpolation is the usual case, so I'll try hacking together a patch for piecewise-linear sampling to test the actual difference.
Are you saying linear interpolation is worse than before? That's definitely the usual case, closest is not important for HDRI backgrounds.
No, that was maybe a bit unclear - I was saying that linear interpolation at 1:1 resolution is still terrible (maybe a tiny bit better, but hard to say), while 2:1 resolution or better now is clean as well, which it wasn't before.
Thanks for the quick fix Lukas. The image is much cleaner indeed :) And requiring twice the resolution only is much better.
