bpy.utils.unregister_module doesn't unregister classes of submodules #50052
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
Reference: blender/blender-addons#50052
bpy.utils.register_module
register classes from submodules correctly, butbpy.utils.unregister_module
doesn't unregister them.I've attached example of a simple addon to check this.
Download and unpack custom_scripts.zip
Scripts
path to point to the root directory calledcustom_scripts
pressSave User Settings
Test
Scripts
field andSave User Settings
Test
panel on theRender
tab is still present. You also can find the corresponding class in bpy.typesIf you will uncomment
bpy.utils.unregister_class(RenderTestPanel)
inui_render.py
and retry all steps, you will see the correct behaviorProbably it's an expected behavior
Added subscriber: @AlexanderRomanov
Added subscriber: @mont29
I do not see any unexpected behavior here? When you clear script field, you just prevents Blender any further access to that addon, so it obviously cannot unregister or re-register that addon correctly anymore. Henceforth, all classes it defined during its last registration remain alive until next start of Blender.
If
callsregister_class
for each submodule class,bpy.utils.unregister_module
must callunregister_class
for that submodules. This is what I am expecting. After clearingScripts
unregister_class
must be invoked fromunregister_module
, which is in memory currently; and yes, register will fail. But we see, thatunregister_class
is not called byunregister_module
, because the pannel is still present.You can see invocation of
unregister_class
, but generator_bpy_module_classes
returns nothing. Seems that the issue is in _bpy_types.TypeMap, or I missed something.PS Now it seems that you don't have to call
register_class
for all your classes, but you have to callunregister_class
OK, confirmed the issue and found the culprit: in reload case (F8), TypeMap is cleared before calling unregister for all active addons, which means all calls to unregister_module will fail.
This was not a visible issue, because reloading that happens immediately after would silently unregister classes already existing, so could only be detected when an addon had gone missing in between.
Will just clear TypeMap after unregistering all addons, see no reason to do it before hand anyway.
This issue was referenced by blender/blender@8f0dc3cef6
