New Dependency Graph - "frame" python driver expression not working #50331
Closed
opened 2016-12-27 19:14:59 +01:00 by Adam W. Parker · 11 comments
Windows 64bit 2.78a
When "frame" is used as expression to drive a value (whether node value, mesh value, or custom property) it does not update upon frame change. User can also manually change the value despite the driver being enabled.
"frame" driver works fine with identical versions with old depsgraph enabled.
T50331_frame_expression.blend
Windows 64bit 2.78a When "frame" is used as expression to drive a value (whether node value, mesh value, or custom property) it does not update upon frame change. User can also manually change the value despite the driver being enabled. "frame" driver works fine with identical versions with old depsgraph enabled. [T50331_frame_expression.blend](https://archive.blender.org/developer/F424121/T50331_frame_expression.blend)
Author
Author
Added subscriber: @AdamParker
Sergey Sharybin was assigned by Aaron Carlisle 2016-12-27 20:57:12 +01:00
I remember fixing related issue. Since there are multiple ways such a driver is created please attach simple .blend file with your particular driver which fails.
Added subscriber: @mont29
@AdamParker please add comments rather than editing original report to answer other comments, otherwise it’s very hard to tell what has been answered or not!
This issue was referenced by a90622ce93
This issue was referenced by a90622ce935acfe769e3100c83a8bb1f5c0ecaec
Added subscriber: @Branskugel
I'd like to resurrect this issue. Stumbled upon it in my personal file. Can be triggered by typing "#frame" into a value field as the quick way to create driver. Triggered in node inputs and object custom properties. Does NOT get triggered if you first add driver through context menu and then edit it either in pop up driver editor or in 'standalone' one
Windows 10 x64, Blender 3.0.1 stable
I'd like to resurrect this issue. Stumbled upon it in my personal file. Can be triggered by typing "#frame" into a value field as the quick way to create driver. Triggered in node inputs and object custom properties. Does NOT get triggered if you first add driver through context menu and then edit it either in pop up driver editor or in 'standalone' one Windows 10 x64, Blender 3.0.1 stable
Can you please submit a new bug report about it?
Checking open reports before submitting bugs is welcome and great and it helps avoiding duplicated reports. For the closed/fixed issues adding more and more specific cases will make it quickly hard to follow or reference from the code or see what exactly was reasoning of specific code to exist.
Can you please submit a new bug report about it? Checking open reports before submitting bugs is welcome and great and it helps avoiding duplicated reports. For the closed/fixed issues adding more and more specific cases will make it quickly hard to follow or reference from the code or see what exactly was reasoning of specific code to exist.
Thank you for pointing me in the right direction, Sergey. I am new to reporting bugs and after I've taken all the necessary steps to make the report I realized that (1) it either has already been fixed or (2) was happening only on my side thanks to an addon. Sorry to bother!
> In #50331#1308741, @Sergey wrote: > Can you please submit a new bug report about it? > Checking open reports before submitting bugs is welcome and great and it helps avoiding duplicated reports. For the closed/fixed issues adding more and more specific cases will make it quickly hard to follow or reference from the code or see what exactly was reasoning of specific code to exist. Thank you for pointing me in the right direction, Sergey. I am new to reporting bugs and after I've taken all the necessary steps to make the report I realized that (1) it either has already been fixed or (2) was happening only on my side thanks to an addon. Sorry to bother!
5 Participants
Reference: blender/blender#50331
