Voronoi texture cells biased towards mapping coordinates #50658
6 Participants
Reference: blender/blender#50658
Archlinux
Broken: 2.78a
When subtracting
(.5, .5, .5)
from the output of a high frequency Voronoi cell texture, a pattern which looks suspiciously like the input coordinates emerges:This might be related to the rather unexpected tendency for Voronoi-cell-modified-normals to cause square reflections of round light sources when used in a glossy shader.
The two phenomena occur together, but beyond that I have no idea why either happens or why one would cause the other.
Added subscriber: @gandalf3
Added subscriber: @GiantCowFIlms
Added subscribers: @brecht, @Sergey
While this isn't really a bug but like a limitation of current hashing function this is an interesting phenomena to investigate.
Think correlation is coming from the order of coordinate components we use to hash r, g and b components:
Would need to plot our
hash()
function to see if there's something intrinsicly wrong in there, but such a quick experiment solves the correlation issue:P446: Snippet for #50658
Note that patch is only working on GPU, CPU would need SSE-optimized version.
That's the math aspect of the issue. Now let's talk about practical aspect. Don't really think Voronoi was intended to have same randomness entropy as a white noise and if you need white noise just use a dedicated function for that. Surely solving correlation issues will be nice, but that's not possible without changing behavior of the voronoi noise. Which means, it'll break all existing files which are using this texture.
Maybe we can do it in 2.8 branch, but only if it's indeed something important to solve.
@brecht, wouldn't mind hearing your opinion on this issue.
Perhaps changing the order to this helps? So there is no repetition in the rows or columns.
Whatever solves the issue, seems ok to fix in 2.8.
Added subscriber: @LazyDodo
Not sure diverging from what OSL is doing is that good of an idea, even for 2.8, We either have to re-implement cellnoise+Voronoi in osl scripts which will be significantly slower, or patch osl while we're building it to keep consistent results between SVM and OSL. Is it really a problem worth solving?
@brecht, woops. After days of bugfix hunting didn't think of such a simple shuffle :) Seems promising since that's simple to implement on SSE.
@LazyDodo, not sure why that would diverge for OSL. We just need to update
kernel/shaders/node_texture.h
. OSL does not implement Voronoi on their side.My bad, i could have sworn we used the internal noise functions from osl. I stand corrected.
My particular use-case is using detailed voronoi cells to modify normals to simulate aluminum flakes in car paint
@LazyDodo, we use noise while voronoi is a "wrapper" on top noise. That being said, we use perlin noise from OS for example.
@gandalf3, why not to use regular noise if the scale to be so small?
@brecht, tested that shuffle patch from you. Unfortunately, it does not solve the issue. So guess our
noise()
function isn't really good in terms doesn't give nice distribution when shuffling arguments around. This is still to be confirmed tho. Will give it a deeper later.@Sergey, it is easier to get distinct faces using the vorinoi texture. Using noise often results in less distinct pieces. Further, for certain camera angles the scale is not as small as one might believe. Some paints have pretty large flecks.
Was trying various things here. The cell-noise itself is not biased by the looks of it, and in fact it matches implementation from OIIO/OSL. it is something combined with the way how we do cells and then hashing the coordinate which gives distribution issues.
Since there is no way to fix that without introducing regressions and because it's not a bug in implementation considering it a TODO for 2.8 projects there: https://wiki.blender.org/index.php/Dev:Source/Render/Cycles/ToDo
@GiantCowFIlms, doubt you'll see bias with larger flecks tbh.
Added subscriber: @sivert3
This is actually cased by a bug in the implementation of quick_floor in OSL, which has been faithfully reproduced in Cycles's own version in util/util_math.h. The gist is that
quick_floor_to_int(-1.0) == -2
instead of the correct value of -1, and this manifests itself in the voronoi shader which floors input coordinates correctly before passing them to cellnoise, which in turn uses the broken quick floor function.See imageworks/OpenShadingLanguage#912 for a detailed description
Confirmed to be the case with P781: Snippet for #50658
