collada export is wrong when done through the API #50923
Closed
opened 2017-03-12 10:03:34 +01:00 by mathieu menuet · 6 comments
All vendors
Broken: latest master
When exporting models through the API, the file created are smaller and make other program crash when trying to import. The exact same objects with the exact same export settings exported through the UI is bigger and import flawlessly in other programs.
Run this script on any file with at least one object selected (like the startup scene with default cube) and try to import the created file (created in the temp folder) in another program like sketchup, it crashes. Blender can import such file.
import bpy
path = bpy.context.user_preferences.filepaths.temporary_directory + "test" +".dae"
bpy.context.scene.collada_export(filepath=path, apply_modifiers=True, export_mesh_type=0, selected=True, include_children=False, include_armatures=False, include_shapekeys=False, deform_bones_only=False, active_uv_only=False, include_uv_textures=True, include_material_textures=True, use_texture_copies=True, use_ngons=False, use_object_instantiation=True, use_blender_profile=False, sort_by_name=False, open_sim=False, export_transformation_type=0)
export the same object(s) through the UI,. Note that the file is bigger and it import flawlessly in other programs.
**System Information** All vendors **Blender Version** Broken: latest master **Short description of error** When exporting models through the API, the file created are smaller and make other program crash when trying to import. The exact same objects with the exact same export settings exported through the UI is bigger and import flawlessly in other programs. **Exact steps for others to reproduce the error** Run this script on any file with at least one object selected (like the startup scene with default cube) and try to import the created file (created in the temp folder) in another program like sketchup, it crashes. Blender can import such file. ``` import bpy path = bpy.context.user_preferences.filepaths.temporary_directory + "test" +".dae" bpy.context.scene.collada_export(filepath=path, apply_modifiers=True, export_mesh_type=0, selected=True, include_children=False, include_armatures=False, include_shapekeys=False, deform_bones_only=False, active_uv_only=False, include_uv_textures=True, include_material_textures=True, use_texture_copies=True, use_ngons=False, use_object_instantiation=True, use_blender_profile=False, sort_by_name=False, open_sim=False, export_transformation_type=0) ``` export the same object(s) through the UI,. Note that the file is bigger and it import flawlessly in other programs.
Author
Author
Added subscriber: @bliblubli
Gaia Clary was assigned by mathieu menuet 2017-03-12 10:04:17 +01:00
This issue was referenced by b759d3c9c5
This issue was referenced by b759d3c9c57683114ae8ff91acea4c29b6afb47e
Member
Member
Hi John;
Thank you for reporting.
The main issue here is that we have some duplication of code which is very likely to deviate. But this will be cleaned up for 2.8 anyways.
cheers,
Gaia
Hi John; Thank you for reporting. The main issue here is that we have some duplication of code which is very likely to deviate. But this will be cleaned up for 2.8 anyways. cheers, Gaia
Author
thanks for the very quick fix :)
Reference: blender/blender#50923
