Broken vertex weights after two mesh joining. #51520
Closed
opened 2017-05-16 13:51:58 +02:00 by Alexander Romanov · 11 comments
Last stable and actual master
After joining of two meshes vertex weights on one mesh become empty.
  • Open the attached file
  • Press Ctrl+J to join them
  • You will see incorrect transform of one of the objects
vertex_weight_bug.blend
**Blender Version** Last stable and actual master **Short description of error** After joining of two meshes vertex weights on one mesh become empty. **Exact steps for others to reproduce the error** - Open the attached file - Select "obj1" and "obj2" ![1.png](https://archive.blender.org/developer/F599965/1.png) - Press Ctrl+J to join them - You will see incorrect transform of one of the objects ![2.png](https://archive.blender.org/developer/F599968/2.png) [vertex_weight_bug.blend](https://archive.blender.org/developer/F599952/vertex_weight_bug.blend)
Author
Member
Author
Member
Added subscriber: @AlexanderRomanov
Added subscriber: @FloridaJo
I find if you apply the armature to the smaller obj1 (small obj) first, then shift sel obj2 then ctrl + J, it works fine.
Bastien Montagne self-assigned this 2017-05-22 13:23:44 +02:00
This issue was referenced by e3d6321530
This issue was referenced by e3d63215308fc2c8b639ee00845344ea735a46e3
Holly cow! Issue here is that CDLayer of vgroups for your MEobj1 mesh has a name - it should not, ever!
Searching in code, found that vgroup edit modifiers dare to create those, will fix, bet you used those here, and applied them?
Holly cow! Issue here is that CDLayer of vgroups for your MEobj1 mesh has a name - it should not, ever! Searching in code, found that vgroup edit modifiers dare to create those, will fix, bet you used those here, and applied them?
Author
Member
Our artist, who found the issue is currently on vacation. I'll ask him as soon as he returns.
Author
Member
He used "Data Transfer" and "Dynamic Paint" and then has applied them.
This issue was referenced by 2fb56e7157
This issue was referenced by 2fb56e71575528be7c1a2b4b4fdf712d971e6eb5
Yuck! Indeed, DynamicPaint was also adding named CD layer for vgroups, tsktsk…
First weight-editing modifiers fix was in e3d6321530, will fix dynapaint now.
Yuck! Indeed, DynamicPaint was also adding named CD layer for vgroups, tsktsk… First weight-editing modifiers fix was in e3d6321530, will fix dynapaint now.
Reference: blender/blender#51520
