Add to Pose-Library doesn't work while tweaking strips in NLA Editor #51607
Closed
opened 2017-05-24 12:38:49 +02:00 by ¿? · 6 comments
Windows 7 64-bit GTX 770
Broken: 2.78 Stable (e92f235283) and 2.78 Daily (7b25ffb)
While trying to add poses to the Pose Library, if you are currently in tweak mode for an action strip, an empty pose will be added to the library instead of the rig's actual/current pose.
Select an action strip >> Press tab (tweak action strip)
Add Pose to Pose Library >> change pose / stop tweaking and (go to a different frame)
Loading the pose will do nothing
NoPoseForLibrary.blend
Repeat steps, without being in tweak mode, and it will work correctly.
While setting up for this report, at one point, it still worked in tweak mode but every prior/subsequent try resulted the same.
It's reproducible, but I can't find any other cause aside from action-strip tweak.
**System Information** Windows 7 64-bit GTX 770 **Blender Version** Broken: 2.78 Stable (e92f235283) and 2.78 Daily (7b25ffb) **Short description of error** While trying to add poses to the Pose Library, if you are currently in tweak mode for an action strip, an empty pose will be added to the library instead of the rig's actual/current pose. **Exact steps for others to reproduce the error** Select an action strip >> Press tab (tweak action strip) Add Pose to Pose Library >> change pose / stop tweaking and (go to a different frame) Loading the pose will do nothing [NoPoseForLibrary.blend](https://archive.blender.org/developer/F608057/NoPoseForLibrary.blend) Repeat steps, without being in tweak mode, and it will work correctly. While setting up for this report, at one point, it still worked in tweak mode but every prior/subsequent try resulted the same. It's reproducible, but I can't find any other cause aside from action-strip tweak.
Author
Author
Added subscriber: @Ebone
Added subscribers: @JoshuaLeung, @mont29
Joshua Leung was assigned by Bastien Montagne 2017-07-04 16:40:47 +02:00
Not sure how much we could support that… @JoshuaLeung another one for you to check I guess?
Member
Member
Looks like you've just got a messed-up Pose Library action.
Looking at it, it's got heaps of random keyframes in there, but no pose markers. Therefore, any attempts to do anything with it will fail.
Looks like you've just got a messed-up Pose Library action. Looking at it, it's got heaps of random keyframes in there, but no pose markers. Therefore, any attempts to do anything with it will fail.
Reference: blender/blender#51607
