SurfacePro 4 + win10: Blank area at top. Mouse click off by blank area size. #51959
Reference: blender/blender#51959
Broken: 2.79 2017-06-09
Worked: 2.78c
Blank (not drawn) area above top menu bar. Using a surface pro 4, I ran at 1920x1080. This produced a blank area above the top menu bar (between the title bar and the info menu bar). This size varies based on resolution, and whether running remote desktop.
The mouse click appears to be off by the height of the blank area. ie - you have to click where the graphics should be and not where they actually are drawn.
To reproduce the error, run at 1920x1080 on a Surface Pro 4 (windows 10). Or run a remote desktop session to a windows machine, and choose 1920x1080 as the resolution.
Added subscriber: @jaimi
Closed as duplicate of #51521
Added subscriber: @brecht
The Surface Pro 4 has an Intel GPU, so it looks like another case of the Intel driver bug.
Not the same as #51521. #51521 says it is broken in 2.78c.
This is not the case for this instance. 2.78c (and earlier versions) work fine.
Changed status from 'Duplicate' to: 'Open'
Added subscriber: @Waterflames
Since you mention 1920x1080 specifically, does it work correctly at the default Surface Pro 4 resolution?
Can any Windows developer reproduce this issue?
@Waterflames, this may be related to the DPI changes.
No, it doesn't work at either resolution - but the amount of empty banding is off by a different amount.
Added subscriber: @mont29
Please:
--factory-startup
commandline option) (this will ensure whether this is a userpref or addon issue or not).Blank area at top. Mouse click off by blank area size.to SurfacePro 4 + win10: Blank area at top. Mouse click off by blank area size.Thank you - I have done the following:
Updated to intels latest graphics drivers. this caused Blender 2.79 to break in a different manner (similar to #51521 ) -- ie, the top part of the info bar was covered by the title bar, and now the mouse was off in the opposite direction. It also caused 2.78c to break in the same way.
I rolled those back to the Microsoft drivers, and 2.78c worked correctly again in all cases.
Tweaking the OGL settings in User Preferences, System had no visible effect.
I then started with the --factory-startup command line option. The screen was off again in 2.79 (though it was off like the new driver was - cutting off the top of the info bar).
Putting the software OpenGL driver in place makes 2.79 look exactly like 2.78c (ie - everything is correctly drawn and it scales correctly).
So, I can only surmise that there is some sort of driver issue, however, it didn't affect 2.78c but does affect 2.79. Hopefully there will be a way to use the old method as well.
Thanks for all the thorough testing, but am afraid this demonstrate once again that issue is with Intel drivers… Not much we can do here, unfortunately, besides waiting and hoping for issue to be fixed in a future driver revision. Thanks for the report anyway.
All I can say is "bummer", as it worked in 2.78c. :(
This is slowly wittling away at the machines I can use Blender on. Can't use it on my Imac anymore because, though 2.6 worked fine, 2.78c renders splotches on the model when you use a normal map. Now won't be able to use 2.79 on my surface.
I wish you could add an option to let it scale the old way, for those of us with hardware that aint going to see no driver updates.
but thanks for looking into it.
I would like to at least investigate this a little since it is a regression due to changes in Blender. I don't think it's obviously true that there is a driver bug here, it may be that the Intel driver just uses the Windows API in a different way that we don't handle correctly, or at least can work around.
I can confirm an issue like this with an Intel HD 4600 on Windows 10 version 1607, when setting "Change the size of text, app, and other items" in the Display settings to something else than 100%. Using an NVidia GTX 1080 on the same computer shows no problem.
This appears to be caused by the new call to
EnableNonClientDpiScaling
, which makes the title bar scale properly along with the application. So far I couldn't find a good workaround besides just not calling that function for Intel graphics. So far I couldn't find any API function (likeGetClientRect
) returning different values for Intel and NVidia. It just seems to draw the contents of the Window with some offset.Is it worth adding a setting to optionally bypass the call to EnableNoClientDpiScaling? Current intel chipsets can run Blender at very good speeds, a lot of notebook and tablet vendors are choosing to not even include discrete chipsets anymore. Even the iris 540 in the surface pro 4 is a credible solution for Unity and Blender.
If we can't find a better solution to this, I think we should automatically not call this function for Intel cards. It's only a cosmetic thing for title bars anyway.
I tried using
SetThreadDpiAwarenessContext(DPI_AWARENESS_CONTEXT_PER_MONITOR_AWARE_V2)
that is available in Windows 10 version 1703, but it has the same issue asEnableNonClientDpiScaling
.Disabling this title bar scaling just for Intel seems difficult, I can only find a way to detect an Intel GPU after the window has already been created. So I'm thinking of just disabling it everywhere and accepting the too small/large title bars until Intel fixes what I presume is a driver bug. Better to have functional software with a small cosmetic issue than not working at all. Unless someone has another idea to try.
This issue was referenced by
0584c5ba8e
I think disabling it is fine. Windows is already scaling the title bar correctly in 2.78c when you change the DPI setting.
