Image Texture Node misbehaving #51989
2 Participants
Reference: blender/blender#51989
OSX Latest
Broken: (2.78a and up)
Worked: (partly) 2.77 !!
Image Texture loading (cycles/internal) does not calculate number of frames when loading and sets a strange offset number
Factory Defaults
Set render engine to Cycles
Go to material tab
Select USE NODES
go to node editor
add an Image Texture node
open a movie
observe strange offset calculation and number of frames not getting updated
(Blender Internal texture has the same issues (guess it's the same code)
When observing this behaviour I wondered when things got messed up and tried several older blender versions from 2.76 uptil now.
It seems that in older versions there was a slightly different behaviour (the offset stayed at 0)
But I noticed when adding an Image Texture node in the material tab did not get frame number updated, while adding a Texture node via the node editor it would!
It could very well be that trying to fix that back then, the new bug got introduced.
Hope you can reproduce it too.
Regards,
Roel
Added subscriber: @kostex
Silly me..
It seems that the filename is causing the 'offset'. If there are numbers in the filename, this gets treated as offset value..
The determination of number of frames is still an issue. (For now ;-)
Searched like crazy to pinpoint where it goes wrong.
My findings are that everything is calculated fine from the movie file (anim_movie.c->IMB_anim_get_duration)
and it shows correctly throughout blender interface and even when querying the loaded movie in console:
bpy.data.images- [x].frame_duration returns the correct number
Only the node itself displays "1"
executing bpy.ops.image.match_movie_length() sets the correct value
So I can only conclude that it's not updating the frame_duration field after a file is loaded
Will search further (I'm not an expert but getting close ;-)
image_ops.c: image_match_len_exec needs to be called???
or iuser->frames = IMB_anim_get_duration set??
Added subscriber: @Sergey
Will have a look when i'm back to office.
Fixed the offset being detected based on movie file name, but movie length detection will need to be done via "Match movie length" button. The reason for that is because image open operator does not have access to movie descriptor or anything. It is possible to make it to behave in a similar way to MovieClip, but that's not really a bug. Added a note in our TODO list: https://wiki.blender.org/index.php/Dev:Source/Development/Todo/Editors#Image_Editor
So thanks for the report, but closing it now.
