OSL trace not working in 2.79 RC! #52368
Closed
opened 2017-08-12 09:51:21 +02:00 by Ilja Razinkov · 13 comments
Windows 10
Broken: 2.79RC 4a1762f
OSL method "trace" not working in 2.79RC (working ok in 2.78), not working at all! +Crashes
Load attached blend and render it. Material on plane below contain osl script, that maps trace calls to pixel color.
shader traceObject(
    output float ishit=0
    ishit = trace(P, point(0,0,1));
In 2.79RC you will get black plane with no signs of successfull trace. In 2.78 you will get torus, projected on plane - trace works as expected.
Also, in 2.79RC i get crashes when rendering this file several times or enabling Rendered preview mode and flying around the plane. They are not 100%, but quite frequent
traceError.blend
**System Information** Windows 10 **Blender Version** Broken: 2.79RC 4a1762f **Short description of error** OSL method "trace" not working in 2.79RC (working ok in 2.78), not working at all! +Crashes **Exact steps for others to reproduce the error** Load attached blend and render it. Material on plane below contain osl script, that maps trace calls to pixel color. ``` shader traceObject( output float ishit=0 ) { ishit = trace(P, point(0,0,1)); } ``` In 2.79RC you will get black plane with no signs of successfull trace. In 2.78 you will get torus, projected on plane - trace works as expected. Also, in 2.79RC i get crashes when rendering this file several times or enabling Rendered preview mode and flying around the plane. They are not 100%, but quite frequent [traceError.blend](https://archive.blender.org/developer/F707903/traceError.blend) ![Scr20170812_278.png](https://archive.blender.org/developer/F707904/Scr20170812_278.png) ![Scr20170812_279.png](https://archive.blender.org/developer/F707906/Scr20170812_279.png)
Author
Author
Added subscriber: @IPv6
Added subscribers: @Sergey, @mont29
Here's ASAN debug build backtrace:
==3773==ERROR: AddressSanitizer: new-delete-type-mismatch on 0x604000261c10 in thread T32:
  object passed to delete has wrong type:
  size of the allocated type:   33 bytes;
  size of the deallocated type: 24 bytes.
==3773==AddressSanitizer: while reporting a bug found another one. Ignoring.
    - 0 0x7fec672bd7c0 in operator delete(void*, unsigned long) (/usr/lib/x86_64-linux-gnu/libasan.so.3+0xc37c0)
    - 1 0x7fec600e5b51 in llvm::BitcodeReader::FreeState() (/opt/lib/osl/lib/liboslexec.so+0x539b51)
    - 2 0x7fec600f5bc3 in llvm::BitcodeReader::~BitcodeReader() (/opt/lib/osl/lib/liboslexec.so+0x549bc3)
    - 3 0x7fec600f5fd8 in llvm::BitcodeReader::~BitcodeReader() (/opt/lib/osl/lib/liboslexec.so+0x549fd8)
    - 4 0x7fec60685369 in llvm::Module::~Module() (/opt/lib/osl/lib/liboslexec.so+0xad9369)
    - 5 0x7fec60540491 in llvm::ExecutionEngine::~ExecutionEngine() (/opt/lib/osl/lib/liboslexec.so+0x994491)
    - 6 0x7fec6011daa2 in llvm::JIT::~JIT() (/opt/lib/osl/lib/liboslexec.so+0x571aa2)
    - 7 0x7fec6011dbf8 in llvm::JIT::~JIT() (/opt/lib/osl/lib/liboslexec.so+0x571bf8)
    - 8 0x7fec5fda188a in OSL::pvt::LLVM_Util::execengine(llvm::ExecutionEngine*) (/opt/lib/osl/lib/liboslexec.so+0x1f588a)
    - 9 0x7fec5fd9d916 in OSL::pvt::BackendLLVM::run() (/opt/lib/osl/lib/liboslexec.so+0x1f1916)
    - 10 0x7fec5fca6eb5 in OSL::pvt::ShadingSystemImpl::optimize_group(OSL::ShaderGroup&) (/opt/lib/osl/lib/liboslexec.so+0xfaeb5)
    - 11 0x7fec5fca86a9 in OSL::pvt::ShadingSystemImpl::optimize_all_groups(int, int, int) (/opt/lib/osl/lib/liboslexec.so+0xfc6a9)
    - 12 0x7fec63aeef95  (/usr/lib/x86_64-linux-gnu/libboost_thread.so.1.62.0+0x11f95)
    - 13 0x7fec651ef493 in start_thread (/lib/x86_64-linux-gnu/libpthread.so.0+0x7493)
    #14 0x7fec5b30fa8e in __clone (/lib/x86_64-linux-gnu/libc.so.6+0xe8a8e)
0x604000261c10 is located 0 bytes inside of 33-byte region [0x604000261c10,0x604000261c31)
allocated by thread T32 here:
    - 0 0x7fec672bcbc0 in operator new(unsigned long) (/usr/lib/x86_64-linux-gnu/libasan.so.3+0xc2bc0)
    - 1 0x7fec606d2d25 in llvm::MemoryBuffer::getMemBuffer(llvm::StringRef, llvm::StringRef, bool) (/opt/lib/osl/lib/liboslexec.so+0xb26d25)
Thread T32 created by T30 here:
    - 0 0x7fec6722af19 in __interceptor_pthread_create (/usr/lib/x86_64-linux-gnu/libasan.so.3+0x30f19)
    - 1 0x7fec63aee2f8 in boost::thread::start_thread_noexcept() (/usr/lib/x86_64-linux-gnu/libboost_thread.so.1.62.0+0x112f8)
Thread T30 created by T21 here:
    - 1 0x563397f6f858 in ccl::thread::thread(std::function<void ()>, int) /home/i74700deb64/blender/__work__/src/intern/cycles/util/util_thread.cpp:29
    - 2 0x5633930054c0 in ccl::Session::start() /home/i74700deb64/blender/__work__/src/intern/cycles/render/session.cpp:131
    - 3 0x563392d7ef91 in ccl::BlenderSession::render() /home/i74700deb64/blender/__work__/src/intern/cycles/blender/blender_session.cpp:472
    - 4 0x563392d6de92 in render_func /home/i74700deb64/blender/__work__/src/intern/cycles/blender/blender_python.cpp:286
    - 5 0x7fec665ec9bc in PyEval_EvalFrameEx (/usr/lib/x86_64-linux-gnu/libpython3.5m.so.1.0+0x1849bc)
Thread T21 created by T0 here:
    - 1 0x563392133c00 in BLI_insert_thread /home/i74700deb64/blender/__work__/src/source/blender/blenlib/intern/threads.c:269
    - 2 0x56338f4a4a15 in WM_jobs_start /home/i74700deb64/blender/__work__/src/source/blender/windowmanager/intern/wm_jobs.c:422
    - 3 0x5633901ffa03 in screen_render_invoke /home/i74700deb64/blender/__work__/src/source/blender/editors/render/render_internal.c:984
    - 4 0x56338f486015 in wm_operator_invoke /home/i74700deb64/blender/__work__/src/source/blender/windowmanager/intern/wm_event_system.c:1130
    - 5 0x56338f48983c in wm_handler_operator_call /home/i74700deb64/blender/__work__/src/source/blender/windowmanager/intern/wm_event_system.c:1782
    - 6 0x56338f48b07f in wm_handlers_do_intern /home/i74700deb64/blender/__work__/src/source/blender/windowmanager/intern/wm_event_system.c:2062
    - 7 0x56338f48b882 in wm_handlers_do /home/i74700deb64/blender/__work__/src/source/blender/windowmanager/intern/wm_event_system.c:2173
    - 8 0x56338f48d7fd in wm_event_do_handlers /home/i74700deb64/blender/__work__/src/source/blender/windowmanager/intern/wm_event_system.c:2539
    - 9 0x56338f46fc33 in WM_main /home/i74700deb64/blender/__work__/src/source/blender/windowmanager/intern/wm.c:504
    - 10 0x56338f465f3a in main /home/i74700deb64/blender/__work__/src/source/creator/creator.c:527
    - 11 0x7fec5b2472b0 in __libc_start_main (/lib/x86_64-linux-gnu/libc.so.6+0x202b0)
SUMMARY: AddressSanitizer: new-delete-type-mismatch (/usr/lib/x86_64-linux-gnu/libasan.so.3+0xc37c0) in operator delete(void*, unsigned long)
==3773==HINT: if you don't care about these errors you may set ASAN_OPTIONS=new_delete_type_mismatch=0
==3773==ABORTING
Here's ASAN debug build backtrace: ``` ================================================================= ==3773==ERROR: AddressSanitizer: new-delete-type-mismatch on 0x604000261c10 in thread T32: object passed to delete has wrong type: size of the allocated type: 33 bytes; size of the deallocated type: 24 bytes. ==3773==AddressSanitizer: while reporting a bug found another one. Ignoring. ==3773==AddressSanitizer: while reporting a bug found another one. Ignoring. - 0 0x7fec672bd7c0 in operator delete(void*, unsigned long) (/usr/lib/x86_64-linux-gnu/libasan.so.3+0xc37c0) - 1 0x7fec600e5b51 in llvm::BitcodeReader::FreeState() (/opt/lib/osl/lib/liboslexec.so+0x539b51) - 2 0x7fec600f5bc3 in llvm::BitcodeReader::~BitcodeReader() (/opt/lib/osl/lib/liboslexec.so+0x549bc3) - 3 0x7fec600f5fd8 in llvm::BitcodeReader::~BitcodeReader() (/opt/lib/osl/lib/liboslexec.so+0x549fd8) - 4 0x7fec60685369 in llvm::Module::~Module() (/opt/lib/osl/lib/liboslexec.so+0xad9369) - 5 0x7fec60540491 in llvm::ExecutionEngine::~ExecutionEngine() (/opt/lib/osl/lib/liboslexec.so+0x994491) - 6 0x7fec6011daa2 in llvm::JIT::~JIT() (/opt/lib/osl/lib/liboslexec.so+0x571aa2) - 7 0x7fec6011dbf8 in llvm::JIT::~JIT() (/opt/lib/osl/lib/liboslexec.so+0x571bf8) - 8 0x7fec5fda188a in OSL::pvt::LLVM_Util::execengine(llvm::ExecutionEngine*) (/opt/lib/osl/lib/liboslexec.so+0x1f588a) - 9 0x7fec5fd9d916 in OSL::pvt::BackendLLVM::run() (/opt/lib/osl/lib/liboslexec.so+0x1f1916) - 10 0x7fec5fca6eb5 in OSL::pvt::ShadingSystemImpl::optimize_group(OSL::ShaderGroup&) (/opt/lib/osl/lib/liboslexec.so+0xfaeb5) - 11 0x7fec5fca86a9 in OSL::pvt::ShadingSystemImpl::optimize_all_groups(int, int, int) (/opt/lib/osl/lib/liboslexec.so+0xfc6a9) - 12 0x7fec63aeef95 (/usr/lib/x86_64-linux-gnu/libboost_thread.so.1.62.0+0x11f95) - 13 0x7fec651ef493 in start_thread (/lib/x86_64-linux-gnu/libpthread.so.0+0x7493) #14 0x7fec5b30fa8e in __clone (/lib/x86_64-linux-gnu/libc.so.6+0xe8a8e) 0x604000261c10 is located 0 bytes inside of 33-byte region [0x604000261c10,0x604000261c31) allocated by thread T32 here: - 0 0x7fec672bcbc0 in operator new(unsigned long) (/usr/lib/x86_64-linux-gnu/libasan.so.3+0xc2bc0) - 1 0x7fec606d2d25 in llvm::MemoryBuffer::getMemBuffer(llvm::StringRef, llvm::StringRef, bool) (/opt/lib/osl/lib/liboslexec.so+0xb26d25) Thread T32 created by T30 here: - 0 0x7fec6722af19 in __interceptor_pthread_create (/usr/lib/x86_64-linux-gnu/libasan.so.3+0x30f19) - 1 0x7fec63aee2f8 in boost::thread::start_thread_noexcept() (/usr/lib/x86_64-linux-gnu/libboost_thread.so.1.62.0+0x112f8) Thread T30 created by T21 here: - 0 0x7fec6722af19 in __interceptor_pthread_create (/usr/lib/x86_64-linux-gnu/libasan.so.3+0x30f19) - 1 0x563397f6f858 in ccl::thread::thread(std::function<void ()>, int) /home/i74700deb64/blender/__work__/src/intern/cycles/util/util_thread.cpp:29 - 2 0x5633930054c0 in ccl::Session::start() /home/i74700deb64/blender/__work__/src/intern/cycles/render/session.cpp:131 - 3 0x563392d7ef91 in ccl::BlenderSession::render() /home/i74700deb64/blender/__work__/src/intern/cycles/blender/blender_session.cpp:472 - 4 0x563392d6de92 in render_func /home/i74700deb64/blender/__work__/src/intern/cycles/blender/blender_python.cpp:286 - 5 0x7fec665ec9bc in PyEval_EvalFrameEx (/usr/lib/x86_64-linux-gnu/libpython3.5m.so.1.0+0x1849bc) Thread T21 created by T0 here: - 0 0x7fec6722af19 in __interceptor_pthread_create (/usr/lib/x86_64-linux-gnu/libasan.so.3+0x30f19) - 1 0x563392133c00 in BLI_insert_thread /home/i74700deb64/blender/__work__/src/source/blender/blenlib/intern/threads.c:269 - 2 0x56338f4a4a15 in WM_jobs_start /home/i74700deb64/blender/__work__/src/source/blender/windowmanager/intern/wm_jobs.c:422 - 3 0x5633901ffa03 in screen_render_invoke /home/i74700deb64/blender/__work__/src/source/blender/editors/render/render_internal.c:984 - 4 0x56338f486015 in wm_operator_invoke /home/i74700deb64/blender/__work__/src/source/blender/windowmanager/intern/wm_event_system.c:1130 - 5 0x56338f48983c in wm_handler_operator_call /home/i74700deb64/blender/__work__/src/source/blender/windowmanager/intern/wm_event_system.c:1782 - 6 0x56338f48b07f in wm_handlers_do_intern /home/i74700deb64/blender/__work__/src/source/blender/windowmanager/intern/wm_event_system.c:2062 - 7 0x56338f48b882 in wm_handlers_do /home/i74700deb64/blender/__work__/src/source/blender/windowmanager/intern/wm_event_system.c:2173 - 8 0x56338f48d7fd in wm_event_do_handlers /home/i74700deb64/blender/__work__/src/source/blender/windowmanager/intern/wm_event_system.c:2539 - 9 0x56338f46fc33 in WM_main /home/i74700deb64/blender/__work__/src/source/blender/windowmanager/intern/wm.c:504 - 10 0x56338f465f3a in main /home/i74700deb64/blender/__work__/src/source/creator/creator.c:527 - 11 0x7fec5b2472b0 in __libc_start_main (/lib/x86_64-linux-gnu/libc.so.6+0x202b0) SUMMARY: AddressSanitizer: new-delete-type-mismatch (/usr/lib/x86_64-linux-gnu/libasan.so.3+0xc37c0) in operator delete(void*, unsigned long) ==3773==HINT: if you don't care about these errors you may set ASAN_OPTIONS=new_delete_type_mismatch=0 ==3773==ABORTING ```
Added subscriber: @brecht
Note the Blender version in the report is not the 2.79 RC build, it's a master build where confusingly the splash screen still shows "Release Candidate". So the crash might also be due to recent changes.
This issue was referenced by blender/cycles@ce7f9aee2e
This issue was referenced by blender/cycles@ce7f9aee2e707f5eeb6cdf2e1218708132608009
This issue was referenced by d7639d57dc
This issue was referenced by d7639d57dc55ee18f7bbed8071efc8f47de1fd04
It indeed was not a bug in the actual 2.79 RC, so no need to backport this one. Also added test for this report.
Author
Thanks for such urgent fixing! It`s really a joy to use Blender :)
This issue was referenced by blender/cycles@5f09155916
This issue was referenced by blender/cycles@5f09155916008ba4fa2bda7ebc7831594415700f
This issue was referenced by 18a353dd24
This issue was referenced by 18a353dd242225a9a7a6e101b9c128f94d03d770
Reference: blender/blender#52368
