Eevee nodes (e.g., Checker Texture) has different coordinates than Cycles when no UV #52528
Reference: blender/blender#52528
Eevee nodes with vector input have a different default coordinate than what is used by Cycles. In blender 2.78, material draw mode, this worked fine.
Open: eevee_default_uv.blend
Then alternate between Cycles and Eevee. The scale of the brick texture is entirely different.
If you connect the Texture Coordinate node in the checker texture it works the same for Cycles and Eevee.
Added subscriber: @dfelinto
Added subscriber: @Sergey
When nothing is connect the coordinated used is the generated (aka orco). The glsl code used to calculate the coordinates is:
@Sergey is this the multiplication you were referring to? Or we actually need something else?
@dfelinto, think so but would double-check tomorrow.
A related issue, which I believe is the exactly same problem.
If you take this Eevee file:
orco.blend
And apply the object scale, the resulting orco (aka generated) texture coordinates are different. I believe the orco attributes passed to the GLSL shader in 2.8 (eevee) is wrong. The shader itself seems to be fine since
0e29a97813
.This issue was referenced by
0feeef89f0
