Disabled Menu Entries with layout.enabled = False can still be executed with generic inbuilt shortcuts #52998
5 Participants
Reference: blender/blender#52998
Win 7 AMD X3 455, R7 360
5c6e3ff
, 2.67bShort description of error
Inbuilt quick access shortcuts for menus can execute the associated entries no matter the UI state of them (disabled by using
)Exact steps for others to reproduce the error
test_menu_shortcuts_error.py
Run script the provided modified template script in the Text editor > Access the Custom Menu in the Info header > Press 1 (One) or T (underscored letter).
Even though the entry is disabled in the menu layout, it still can be accessed with these inbuilt generic Menu shortcuts.
It's not that a big of an issue in case of operators behind a poll but it can lead to crashes if something was disabled in the UI for a reason.
Added subscriber: @VukGardasevic
Added subscriber: @Sergey
Everything is working according to a design here.
Enabled
only makes widgets greyed-out, but still allows to tweak values and such. For example, you can do necessary tweaks to shutter duration even while Motion Blur is disabled in render settings.What you should be doing in this particular case is to declare operator's
poll()
function which will check whether operator can or can not be run within the current context. If operator is forbidden to run in current context,poll()
should returnFalse
and it will make corresponding entry in menu to be greyed out and will also exclude the operator from running via shortcuts.Thanks for the report, but it is how Blender works.
Maybe i wasn't being clear enough with the example, so I apologize.
For Menu entries, both
enabled
andactive
set to False will not allow tweaking of properties. Otherwise can be true for panels, but menus are specific.test_menu_shortcuts_properties.py
Also accessing properties like scene ones with number shorticuts in menus (like 2, 3 depending on their order in the menu) will reset the value to the defined minimum one.
Added subscriber: @mont29
Well, technically you shouldn't be adding props to menus, this is highly discouraged by interface guidelines. But maybe we should make those behave same for both menus and panels.
@mont29, can i assign it to you and have your opinion here? :)
Am pretty sure it’s not worth spending time to fix/hack/workaround this unsupported, unrecommended "feature"… Properties are for panels, if this is really to be solved, I’d simply forbid props in menu layouts, done. Because I suspect getting all different 'keyboard users' here (menu entry selection/'shortcut', widget itself…) to play nice and sound together won’t be easy.
Added subscriber: @brecht
I'll fix this bug.
Properties in menus are used in various places, like the Render menu or graph editor View menu, we can't simply remove that.
This issue was referenced by
64f8cc3e7d
