Weight paint crash when subsurf modifier is not first (master not 2.79) #53551
5 Participants
Reference: blender/blender#53551
When there is a mirror modifier before subsurf for example, weight painting crashes, since the indices used are assumed to be aligned with the
Mesh
data-block.(assumption from PBVH vertex paint merge).
Try paint on both examples in the attached file:
subsurf_crash.blend
Added subscriber: @ideasman42
Weight paint crash when 2x subsurf modifier is not firstto Weight paint crash when subsurf modifier is not firstAdded subscriber: @JohnRoper
Blender crashes when I try to weight paint the first example (the single cube). Blender does not crash when I try to paint the second example (the two cubes).
The second example crashes if you paint in some locations. It works sometimes because mirror modifier may correctly reference original vertices.
Added subscriber: @Sergey
@ideasman42 , if you report issue, make sure it's assigned to a maintainer. In this case regression goes to
4f616c9
.Weight paint crash when subsurf modifier is not firstto Weight paint crash when subsurf modifier is not first (master not 2.79)Added subscribers: @nathanvollmer, @mont29
@Sergey, actual code was something the @nathanvollmer & @mont29 developed.
From a quick look am not sure how to solve, besides not supporting multires and instead always weight painting on the deformed cage as 2.79 does.
Checked on using orig-index here but the data layer isn't available.
This issue was referenced by
ad046efa79
