Motion Tracking Object Solver Constraint doesn't work as Bone Constraint #53691
Reference: blender/blender#53691
Windows 10
GTX970
16GB RAM
Bottom Line: Applying an object solver as a bone constraint does not change the bone's location/rotation/scale during animation (it doesn't seem to affect it).
NOTE:Sorry for all the edits, I'm just continuing to add details and clarifying as I felt was needed. Hopefully nobody takes issue to the long list!
(<-This was accidentally linking to a different post, that has no relevance to this one, so I put it in code tags, however the link to that unrelated post still exists at the bottom of this page.)
It doesn't work in 2.78 or 2.77 official builds.
It may work in Blender 2.78 (I'm downloading a 2.78 and 2.77 build now to test) asI have an older file where I have a working object track constraint on a bone. See below.It is entirely possible I'm missing a step, but I was able to set this up (I don't remember how long ago) and it worked, and following the steps below in 2.79-2.77, it does not. I'm not 100% sure if it's a bug or I'm making an error. Hopefully it's just me making an error!
When the object solver constraint is added to the bone, it causes the location of that bone to initially change indicating to me that the solver is applied and is having an affect on the bone, however no motion happens on the bone as animation is played (it doesn't continue to follow the tracked object). The same solver applied to a cube is working perfectly. I have attached a file that I hope will still work without the footage attached. If not, I'll render a proxy of the footage.
I have a project from an earlier version (I don't remember when) that has a working object solver constraint on a bone, and when loaded into 2.79 the constraint works. If I delete that constraint and then add it again, even in 2.79, once set to the proper tracker, it still works and affects the bone justas it should.
Also, as a weird side note that may help diagnose the problem, when I use this older file in which the constraint works, and I try to bake that constraint to an F-Curve I get an
error. So maybe some mix up or regression in syntax between
2.78an older version and 2.79?I cannot say for 100% sure that it works in 2.78. I'll try to download 2.78 and test this there as well.Based on a (as simple as possible) attached .blend file with minimum amount of steps
{F1682547}
In this file, all the tracking is already set up. It shows that the constraint works on the cube, but doesn't on the bone as a bone constraint.
To do it from a fresh file:
Add an object solver as a bone constraint.
Play animation
Hopefully this all makes sense, let me know if you need any clarification!
Added subscriber: @MatthewHoecker
Motion Tracking Object Solver constraint doesn't work as bonesto Motion Tracking Object Solver Constraint doesn't work as Bone ConstraintAdded subscriber: @lichtwerk
I can confirm its not working in the provided file.
First findings: if you add another bone constraint in the constraint stack [e.g. copy location] the object solver constraint on the bone will start to work.
(It doesnt really matter what kind of properties you set in the 'other' constraint -- could be inactive/hidden even...)
@MatthewHoecker: could also be helpful if you could share the other .blend you mentioned (the one where the object solver constraint on the bone was actually working). Could you post this here?
not happening with the new dependency graph btw. ( when you start blender with
blender --enable-new-depsgraph
)Added subscriber: @Sergey
with the old dependency graph
objectsolver_evaluate()
is called on file load but not on playback@Sergey: could you have a look? If its an easy fix, give me a hint, I'll do then
@lichtwerk Here's the file, all pared down from the original, but has the motion tracking data, and the working constraints.
Object Constraint Working Test.blend
This issue was referenced by
f5d64b59f5
