Draw curve fails if you stop press action before separe stylus. #53752
Reference: blender/blender#53752
Windows 7 64bits
Wacom Intuos L
blender 2.79 and master
The problem derivate of change "left/right" click in the preferences and use left click by default. Basically when you paint a curve, in edit mode inside a curve, with the wacom the action button is different to tip of the stylus, so, to take the pressure info you need to first press the second click in the wacom (some of the other buttons) and then use the tip to pick the pressure info. But if you don't separate the stylus before unpress the other button the operation is ignored.
With normal right click by default it doesn't happen. But if you use left click (the normal behaviour for a lot of people and the normal outside blender) the tool don't work correctly and it's hard to understand the reason. One solution can be change the shortcut to tip of the wacom, but then each time that you try to make a selection you could draw a curve. Anyway, for a user that use left select and a wacom the behaviour is similar to a bug.
0001-0250.mkv
In the video you can see two different bugs. One is the problem that I talk in https://developer.blender.org/T53553 the other is the problem that talk in this report.
Change the left/right click default and try to paint a curve.
Added subscriber: @AlbertoVelazquez
Added subscriber: @lichtwerk
As a first step you could set the Input from
Mouse > Action
toMouse > Pen
in User preferencesAdded subscriber: @ideasman42
@ideasman42 : since afaik having multiple keymap entries is allowed, I guess D2994: fix #53752 would do no harm?
The problem changing the action to the pen is the same that using "select". You cannot do multiple selection with shift+click with tip. So, it is not a solution.
This issue was referenced by
d0cc5d8948
With this commit we don't have now the possibility to make a simple shift-select with the stylus.
@AlbertoVelazquez: Maybe I'm missing the obvious, but shift-select with stylus still works here.
Could you try with factory settings and the default Keyconfig?
If you use the default keyconfig, without the left click, the bug doesn't exist, then the fix don't have reason
If you use the default keyconfig, with left click, the bug exist and with new configuration the user cannot make shift+select.
Yes, I meant with left click as well [and that is still working on my side...]
@AlbertoVelazquez: could you do me a favour: can you open separate bugreport for this? You can mention this original task and the commit there. But this way it is more visible for others (also to help out reproduce)
Thx in advance
@AlbertoVelazquez: I guess I didnt see the obvious (sorry for this)
So it indeed conflicts with shift+select in curve editmode
@ideasman42: I think we better revert this then for now?
appologies to everyone involved for not having this on the radar :S
will think about better solutions later...
