Whitespace in VDB grid names #53802
Closed
opened 2018-01-16 15:19:35 +01:00 by Thomas Volkmann · 10 comments
From the smoke export Wiki page:
"If high resolution is enabled, the corresponding low resolution fields are suffixed with " low"."
Can this please be changed so the whitespace gets replaced with an underscore "_low".
Having a whitespace in the vdb grids causes some confusion when inspecting the vdbs in other software (in this case Arnold).
The list of available grids reads like this:
color color low density density low heat heat old obstacles shadow texture coordinates velocity
Thanks!
From the smoke export Wiki page: "If high resolution is enabled, the corresponding low resolution fields are suffixed with " low"." Can this please be changed so the whitespace gets replaced with an underscore "_low". Having a whitespace in the vdb grids causes some confusion when inspecting the vdbs in other software (in this case Arnold). The list of available grids reads like this: color color low density density low heat heat old obstacles shadow texture coordinates velocity Thanks!
Added subscriber: @knekke
Member
Added subscribers: @kevindietrich, @lichtwerk
Kévin Dietrich was assigned by Philipp Oeser 2018-01-18 18:07:50 +01:00
Member
I can see this getting annoying [although I could find anything in the spec stating that those names are not allowed...]
@kevindietrich: what do you think?
I can see this getting annoying [although I could find anything in the spec stating that those names are not allowed...] @kevindietrich: what do you think?
Added subscriber: @brecht
@lichtwerk, I think it's reasonable to use an underscore, it does seem to be the convention for VDB files.
If we change this then the code to read VDB files should still try both "_low" and " low" though, for backwards compatibility.
If you like to fix this go ahead I think, otherwise close as not a bug.
@lichtwerk, I think it's reasonable to use an underscore, it does seem to be the convention for VDB files. If we change this then the code to read VDB files should still try both `"_low"` and `" low"` though, for backwards compatibility. If you like to fix this go ahead I think, otherwise close as not a bug.
This issue was referenced by 6d8a4c10b6
This issue was referenced by 6d8a4c10b65c45b2bcc2eca7779cc541af0562fb
Member
having trouble building with openvdb right now [/usr/bin/ld: vdb_print: hidden symbol `__cpu_model' in /usr/lib/gcc/x86_64-redhat-linux/7/libgcc.a(cpuinfo.o) is referenced by DSO]
as soon as this is out of the way, I'll have a look
having trouble building with openvdb right now [/usr/bin/ld: vdb_print: hidden symbol `__cpu_model' in /usr/lib/gcc/x86_64-redhat-linux/7/libgcc.a(cpuinfo.o) is referenced by DSO] as soon as this is out of the way, I'll have a look
@lichtwerk if you have trouble building OpenVDB, I can quickly make a patch for it.
Member
@kevindietrich : yes, please go ahead, thx!
5 Participants
Reference: blender/blender#53802
