Enabling weight brush in particle edit mode of a hair particle system will cause a crash when entering an emitter system edit mode. #53823
Reference: blender/blender#53823
Ubuntu 16.04 and Nvidia Ttan Black proprietary driver 384.111
Broken: official 2.79 and
7b3e441
In particle edit mode, you can add or remove weights to hair paths.
You have to enable weight brush for that.
But you can not do it for emitter particles.
So, if you enter into particle mode of a particle system to change weight on hair and quit it with weight brush enabled.
When you will enter particle edit mode of a baked emitter particle system, Blender crashes.
particle_weight_crash.blend
In attached .blend file, select Cube with hair.
Enter into Particle Edit mode.
Select Weight Brush.
Quit to Object mode.
Select plane with baked cache of emitter particles.
Enter into Particle Edit mode -> crash
particle_weight_crash.crash.txt
Added subscriber: @zeauro
Added subscribers: @ideasman42, @lichtwerk
Can confirm this, D3008: #53823: prevent crash prevents the crash, but maybe we should spend time making sure we only have the weight brush available for hair? (@ideasman42 : I could have a look if this is worth the time...)
This issue was referenced by
368414efac
