Can not import .obj or .fbx generated from Marvelous Designer #53841
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
6 Participants
Reference: blender/blender-addons#53841
windows 10 , gtx 1060
Broken: 2.79 42a5624
as title,
here is the error information
importing .obj file gives similar error.
Added subscriber: @yifei
katou-和服.fbx
Added subscriber: @ArtoKitula
Could you add obj file instead of fbx?
Added subscriber: @cyaoeu
As a temporary workaround you can change line 127 and forward in import_fbx.py (see the path of the error) to this:
katou-和服.obj this is the .obj file
Added subscriber: @lichtwerk
@cyaoeu : thanx for investigating
how about {D3012}?
OBJ importer works for me though (it is using above method - using a replacement character - already btw...)
Regarding OBJ file, I guess we have no issues here because we do not have the MTL file associated with it (its path is the only textual info in an OBJ file I think…).
FBX is another topic, as stated by the official doc, FBX uses utf8 unicode encoding internally. This means that that FBX file is seriously broken imho. Will add the 'replace' option from D3012, won't hurt probably, but this should absolutely not be needed. At all. Suggest you report the issue to Marvelous Designer team (and as a side question, does this FBX file loads OK in e.g. Maya or 3DSMax?).
This issue was referenced by
5804465558
29ae03c572
I dont have maya or 3ds max. this fbx is ok with windows 3d painter and daz studio. I tried to open in daz and save again to work around but it introduced some daz studio things not needed. I suspect that the reason it cannot be opened in blender is that I put chinese character in file name when I saved it in marvelous designer. Marvelous Designer uses fbx sdk, it should be ok with maya and 3ds max in my opinion.
Then it means that FBX SDK does not even respect its own documentation (what a surprise…)
Anyway, fix is committed, Blender shall now be resilient to badly encoded strings.
Btw, Chinese characters are not an issue in themselves, here issue is that the strings are not encoded in valid utf8 as expected (no idea what's used instead, could be some Windows-specific Chinese encoding …).
