Clearing followed by setting a listbox created by UILayout.prop_search while keeping the mouse on the listbox crashes Blender #53845
6 Participants
Reference: blender/blender#53845
OS: Ubuntu 16.04 x86_64
Gfx: Intel HD Graphics 530 (Skylake GT2) (driver: GL 4.5 (Core Profile) Mesa 17.3.0-devel)
Broken:
Clearing followed by setting a listbox created by UILayout.prop_search while keeping the mouse on the listbox either crashes Blender or leads to unexpected behaviour.
Consistently reproducible.
Expected behaviour of step 6.
Step 6 should be able to behave as step 4, i.e., one should be able to again select something from a non-empty list
Observed behaviour after step 6
One of following, probably depending on how Blender's memory was allocated:
Appendix A
Terminal output upon crash
Contents of "blender.crash.txt"
Added subscriber: @Eliasvan
Added subscriber: @lichtwerk
can confirm list is empty in master (cant get it to crash here), sometimes theres an entry with a garbled name [accessing bad memory?]
2.79 and below crash. will have a closer look later.
Added subscriber: @ideasman42
@lichtwerk do you have address sanitizer setup? - it shows the cause fairly clearly the cause of the error, though exactly how to fix isn't obvious.
@ideasman42 : thx for the tip, will do in 3hrs and check again
OK, that ASAN is really useful! (already have a couple of other reports in mind on where to use it...)
In this particular case/report I'm still examining those two codepaths (where allocated and where freed) in more depth. Lots of (new) stuff to read for me and wrap my head around, but I'm on it...
Added subscriber: @iss
Not sure if this is somehow reproducible in 2.8, but haven't tested with ASAN yet.
Added subscriber: @dr.sybren
Changed status from 'Confirmed' to: 'Needs User Info'
I can't reproduce this issue in 2.79b or latest master (
be8879718e
). This is the blend file I used: #53845-clear-listbox-ui-crash.blend@Eliasvan Please check that the latest Blender build from https://builder.blender.org/ still crashes on this. If it does, please give us the exact steps to reproduce the issue.
The crash is being blocked by #69200 (Resetting default value does not work in popovers or menus), with this fix applied, the error can still be redone:
A naive fix to redo the error.
Added subscriber: @Mysteryem-2
It looks like some updates to Blender in 2.81.x altered the effect of this issue. Testing on 2.81.16, 2.82.7, 2.83.19, 2.90.1, 2.91.0, 2.93.7 and 3.3.0 on Windows 10 (with the same script, except defining the StringProperty as an annotation instead of using assignment), no crash occurs, instead, the 'redo toolbar panel' closes itself when the 'x' of the property is clicked. 2.80.75 is the newest version that crashed for me, though I didn't test any older versions of 2.81.x.
