group objects and their counts become mismatched in particle system "use count" list #54257
Reference: blender/blender#54257
Linux Mint 18 Cinnamon 64-bit
system-info.txt
Broken: official release 2.79a, latest build 2.79.3
76122bc8f0
Earliest release with bug was 2.78a; 2.78 had a different bug (all counts become 1).
Sometimes particle system's render->group->use count (dupliweight) list will rearrange (alphabetise) object names but not the counts, so they become mismatched.
The bug occurs on changing values in the redo panel, or on loading a saved file.
FROM DEFAULT SCENE:
Now, EITHER: add another object, and change some value for it in the T-Panel (redo panel); OR save and reload the file (the list will show "no object" at first - mouse over it or something to update it).
EXAMPLE FILE (produced by following steps 1-6 then saving)
groupCountBugExample.blend
Expected Results:
Ideally nothing should change, but if it must, the count list (Suzanne: 25, Icosphere: 1) should become (Icosphere: 1, Suzanne: 25).
What happens instead:
The list becomes (Icosphere: 25, Suzanne: 1).
Added subscriber: @tomjk
Added subscribers: @mont29, @lichtwerk
Can confirm this, looking a little further now, but if that gets a timesink, I might need @mont29 to have a look here
possibly related #53628 (but that needs reconfirmation once a solution is found here)
OK, actually group indices seem to update/change on save then reload...
Hm, apparently that has always been the case [checked back to 2.74]
can easily be verified in python, too:
bpy.data.groups['Group'].objects- [x]
[should result in 'Cube']bpy.data.groups['Group'].objects- [x]
[should still result in 'Cube']bpy.data.groups['Group'].objects- [x]
[should now result in 'Suzanne']If that is the case, then relying on storing the group index in
ParticleDupliWeight.index
and restoring the objects from that said index is not a good idea, I guess?stored in write_particlesettings
not restored in lib_link_particlesettings
but in psys_check_group_weights
Hm, what to do? do this namebased instead? Can we change/force above said change of indices before writing the file (so we dont run into the mismatch later?)
Of course I could be missing something, happy to try something more, but kindly asking @mont29 for advice before I sink more time here... [just assign back to me and I will try more]
Added subscriber: @Sergey
Hey,
so group objects are not reordered on read file, but according to Dr @Sergey bloody depsgraph can reorder them at some point. This is sort of can of worms, and probably not worth spending too much time on it since it will be fixed in 2.8 by CoW (i.e. depsgraph will no longer ever touch to actual DNA data).
So think this can be closed as 'known bug, won't fix in 2.7x, will be fixed in 2.8'?
as @mont29 said, we will archive this then as 'known bug, won't fix in 2.7x, will be fixed in 2.8'
