I can't used ' Grease Scatter Object' #54528
Closed
opened 2018-04-05 07:18:38 +02:00 by Jang, Hong-Tak · 6 comments
intel i7-6700, GTX1060
2.79b
Broken: Grease Scatter Object - The function does not work at all.
Worked: I can't used ' Grease Scatter Object'
Grease Scatter Objects.blend
**System Information** intel i7-6700, GTX1060 **Blender Version** 2.79b Broken: Grease Scatter Object - The function does not work at all. Worked: I can't used ' Grease Scatter Object' [Grease Scatter Objects.blend](https://archive.blender.org/developer/F2604237/Grease_Scatter_Objects.blend) Based on a (as simple as possible) attached .blend file with minimum amount of steps
Author
Added subscriber: @HongTakJang
Author
Removed subscriber: @HongTakJang
Author
Member
Added subscriber: @lichtwerk
Member
Philipp Oeser self-assigned this 2018-04-05 10:25:35 +02:00
Member
In your example file you are trying to scatter on a flat plane (which is not the expected input -- the addon needs corners/cavity to work properly)
If you modify your file slightly by extruding some edges as to have corners/walls, it should work as expected.
Grease Scatter Objects working.blend
Also see the (minimal) addon doc [here ]] or the BA thread [ https:*blenderartists.org/forum/showthread.php?227489-Grease-Scatter-(Addon) | here
Closing, as there doesnt seem to be a bug here
In your example file you are trying to scatter on a flat plane (which is not the expected input -- the addon needs corners/cavity to work properly) If you modify your file slightly by extruding some edges as to have corners/walls, it should work as expected. [Grease Scatter Objects working.blend](https://archive.blender.org/developer/F2605112/Grease_Scatter_Objects_working.blend) Also see the (minimal) addon doc [here ]] or the BA thread [[ https:*blenderartists.org/forum/showthread.php?227489-Grease-Scatter-(Addon) | here ](https:*wiki.blender.org/index.php/Extensions:2.6/Py/Scripts/Object/Grease_Scatter) Closing, as there doesnt seem to be a bug here
2 Participants
Reference: blender/blender-addons#54528
