Corruption in Default Scene Primitive #54583
Reference: blender/blender#54583
Win 10
NVIDIA Titan X Pascal
(DxDiag.txt attached with detailed config)
Broken: 2.79b (22-03-2018)
The default scene displays corruption on opening the app. This behaviour has persisted despite several reinstallations. All settings are at factory defaults.
Intersect (Boolean) operations do not work. Either the selected object disappears and is reduced to an origin with no dimensions or there is an error stating that no intersections are found, despite the two objects clearly overlapping. Difference and Intersect result in the object selected disappearing. Union results in the error message. The operation has worked twice, the second time produced erratic results on the geometry which was not expected.
Update 14/04 : The corruption is now present in a model I have created, rendering the app almost unusable. I have now attached a video of the behaviour. It 'seems' related to the UI as there is also corruption in the menus and interface. As mentioned this is a fresh install with factory default settings and has repeated across different installs. I will try a previous version to see if the behaviour is present.
I have tested prior versions, this behaviour started in V2.60. V2.59 works fine, in fact it is a lot smoother than more recent versions. Interestingly the experimental V2.80 build works fine as well, and looks a lot better. So this issue ranges from versions 2.60 - 2.79.
For the first point, open the app and click past the spash screen. Then simply rotate the camera and/or press tab to enter edit mode.
For the second, using the default cube scene, duplicate the cube, move it to 1:1:1 so that a corner overlaps, then use Intersect (Boolean) - Ctrl F from Edit Mode, pick option from menu. The selected cube is reduced to an origin.
I've attached two screenshots, the default blend file and DxDiag file.
Many thanks,
Roy
bug.blend
DxDiag.txt
BlenderCapture.mp4
Added subscriber: @vahndaar
Added subscriber: @lichtwerk
Dont have issues in your provided .blend
Think there are two issues to solve here:
Its highly likely that this bug is specific to your hardware/driver configuration. These kinds of display issues are often caused by OpenGL driver bugs.
While its possible a software error in Blender, its worth checking if this functions correctly...
If this is a driver bug, or we can't link to this to an error in Blender's code, the report may be closed as a driver error, so please help us determine whether this is a bug in Blender or not.
Marking as incomplete until we have these questions out of the way...
Added subscriber: @VukGardasevic
More than a week passed without a reply.
Due to the tracker policy, archiving until the required additional information / data is provided.
