Material Library VX - Add Active Material to library disfunctional #54701
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
Reference: blender/blender-addons#54701
Windows 7 64 Bit, Nvidia GTX 1060
Broken: (example: 2.69.7 4b206af, see splash screen)
2.79b
Clicking at the Add Active Material to library button in the Material Library VX addon is disfunctional. The status bar tells me that the material is added. But nothing happens.
Activate the Materials Library VX addon. Create a new material. Doesn't matter if BI or Cycles. Go to the addon. Click at the Add Active Material to library button. Have a look if anything arrives. Here nothing happens. What i get is some messages in the console. Which tells me about not found paths and that the material is added ...
The Material Library VX Addon is included in Blender.
Added subscriber: @tiles
Added subscriber: @StephenLeger
Not found path message is related to "user defined path" to library not set in addon preferences. It is only info and can't be the source of any error.
By default the addon seek for library in addon folder - when setup into blender addon folder you may facing with "read only" folder issue leading to write into library error.
Properly setting a "user defined path" into addon preferences to a writable folder allow to overcome this known issue - see matlib_vx thread on blenderartists.org as reference.
Thanks for the idea stephen, but it's not a rights issue. The folder is writable. I have meanwhile found out what it is. You can't add a material as long as the filter categories button is active. The way it works is:
And then the new material should be in the category where you want it to be. And is saved in the addon.
So the original error is solved meanwhile, it works as designed. Even when the design is a bit more complicated. < The only thing that i could suggest is to add more descriptions to the tooltips. Or maybe a help text in the addon panel in the user preferences. Or both.
But at the step to click at the arrow button i stumbled across another problem meanwhile. When i turn the library on, and then click at the arrow button, then i get a error message.
Added subscriber: @lichtwerk
Even though the first issue seems fixed I can confirm the second ('xml is not defined')
This seems like outdated code (had a quick look at it, but there is also seemingly other outdated stuff flying around, e.g.
current_library.materials
, ...)@StephenLeger: mind having a look? Otherwise I'm tempted to just remove that code path (but havent looked in depth)...
Missing proper xml import
Never checked category stuff, i only made some cosmetic changes during 2.79 release process related to user defined library path and fixed temporary scripts path to writable folder.
Will probably require more in depth investigations of overall code, might take a look next week.
@StephenLeger: ok, I have a fix, will push tomorrow...
regarding the xml error: I pushed
8d3301f66c
now.Closing the whole report as resolved then.
Sorry for resurrecting this thread. I have compiled the newest Blender version, and stumbled across that the fix has introduced a few error messages now at switching the libraries. The version included in 2.79b doesn't show this behaviour.
Warning: 'matlib.libs_menu' doesn't contain 'MT' with prefix & suffix
Warning: 'matlib.cats_menu' doesn't contain 'MT' with prefix & suffix
Warning: 'matlibvxPanel' doesn't contain 'PT' with prefix & suffix
This warning is not related to that fix, it was introduced in master in blender/blender@0bbae3f3f6 and blender/blender@94b7bf3ec2 [which is not part of official 2.79x releases afaik] and just tells addon devs that bpy types such as menus, panels etc. should follow a strict naming convention [which obviously a lot of existing addons dont do...]
Ah, i see. Many thanks :)
This three error messages comes by the way from this addon :)
Created a new task for it https://developer.blender.org/T54803
