Append already linked Data #55629
10 Participants
Reference: blender/blender#55629
Broken: 2.8
e17285a381
When appending data that is already linked into the file, it will also be linked instead of being made local.
Added subscriber: @JulienKaspar
#92688 was marked as duplicate of this issue
#86691 was marked as duplicate of this issue
#84900 was marked as duplicate of this issue
#79903 was marked as duplicate of this issue
#67740 was marked as duplicate of this issue
Added subscriber: @Alex_Rom
Added subscriber: @Alex3
Have been working on this today, have it partially working (crashes still a lot, the append part of the code is very complicated :( ), but am hitting some design issues actually.
Thing is, in append, after linked data has been made local, we remap all its local usages to the local data-block. It means that if e.g. you have assigned a linked material to some local object, then decide to append that same material, currently your already existing local object will be also remapped to use the new local copy (appended version) of the material. I kind of have the feeling that this is not the desired behavior?
Added subscriber: @dfelinto
(@mont29 is this still even an issue? if not maybe even the patch can be archived)
@dfelinto
Added subscribers: @ZachHixson, @lichtwerk, @mont29
Added subscriber: @importsjc
Hi all,
Just wanted to provide a workaround for this issue. I found that if you save the blender file, that you are appending data from, with a new name (eg "Model_V1.blend" -> "Model_V2.blend") the data will be appended without any linking!
Hope this helps someone and that I provided this feedback in the correct manner.
Added subscriber: @Masterheavy
Thanx Stephen for this workaround - but it actually don't work in the 2.90.1 version I have here - saving the library file with a new name or renaming a copy of the file does not change anything on the append behavior.
Only renaming the collection, before saving a different file seems to work.
Good to know! I'm using 2.90.0. I'll holdoff upgrading until there's a fix/workaround in a newer version.
Added subscribers: @Vyach, @TheCharacterhero-4
Added subscriber: @YegorSmirnov
Added subscriber: @craigievar
This issue was referenced by
3be5ce4aad
Added subscriber: @Rawalanche
