Culling not working correctly when using array modifier #57389
5 Participants
Reference: blender/blender#57389
Windows 10, GTX1070
Broken: Blender 2.8 Alpha 2
e66084268c
When you add an array modifier to an object, and move the original object off-screen ( with the cloned objects still on-screen ), the cloned objects disappear.
Note that if you save and re-load this file, the culling is fine, so I wasn't able to attach a .blend to show this.
Added subscriber: @MalDuffin
Added subscribers: @mont29, @lichtwerk
Can confirm, indeed caused by
e66084268c
.This is not only affecting view culling but also Bounds display_type etc..
(Interestingly before that commit [while dimension were broken] bounds drawing was actually fine...)
You can also go in and out of editmode (or change some prop on the array modifier) to get your proper bounds back (
BKE_mesh_eval_geometry()
gets called), but as soon as you start transforming, you will loose it again (becauseBKE_object_eval_done()
kicks in again)Still not familiar enough with dependency graph, @mont29: looks like bbox is calculated for "non-obdata-evaluated" object? (need to read more [depsgraph-]code here...)
Added subscriber: @brecht
I think the bounding box is being computed too early, after the transform but before modifiers are evaluated.
It might need to be in both the object transform and mesh update, because they could be updated independently.
btw. we have another (possibly related) boundingbox issue in #57070...
Just a follow up here, current bbox code is actually a real nightmare to follow, and is doing lots of bad things (now that we are in COW era)… Still working on trying to understand what happens, and how to fix it. :|
This issue was referenced by
5f6fae9ad0
