Object.ray_cast (and all RNA functions using "ob->runtime") broken in Blender 2.80 #57861
6 Participants
Reference: blender/blender#57861
macOS X Mojave with GTX 980
Broken: 2.80.
59f0db430a
Worked: no solution
Object.ray_cast is broken in Blender 2.80.
I have attached a blend that contains a simple ray_cast that works in 2.79 and fails in 2.80. Run blender from a console to see the error messages.
Click Run Script to see the result of ray_cast in Blender 2.80
ray_cast_test.blend
Added subscriber: @KofiGarbrah
blender/blender-addons#58317 was marked as duplicate of this issue
#59791 was marked as duplicate of this issue
blender/blender-addons#59790 was marked as duplicate of this issue
This comment was removed by @KofiGarbrah
Added subscriber: @lichtwerk
Confirmed, will have a look...
Added subscribers: @mont29, @brecht
Hm, seems like since the removal of DerrivedMesh from RNA (
79615c5adb
) there are a couple of issues.Checked
rna_object_api()
and all RNA functions usingob->runtime
fail.rna_Object_ray_cast():
rna_Object_closest_point_on_mesh():
rna_Object_me_eval_info():
ob->data
directly)@mont29: any ideas here (assigning to you first)?
or maybe @brecht can comment?
@KofiGarbrah: As a (temporary) workaround for this report you can create a BVH manually and raycast that:
Object.ray_cast broken in Blender 2.80to Object.ray_cast (and all RNA functions using "ob->runtime") broken in Blender 2.80Imho there is no bug here… that has more to see with how blender/depsgraph/CoW work now in 2.8. Original data (from Main, of
bpy.data
in python) is not supposed to have evaluated stuff, although we do 'backport' a few things for objects…You should use context's despgraph object, something like:
if obj.type == "MESH":
obj_eval = depsgraph.objects.get(obj.name, None)
if obj_eval is not None:
print(obj_eval.ray_cast(start_ray, dir_ray))
I would expect this ray cast function to get a depsgraph parameter, which it will then look up the object in. That will at least make it more clear to users what is missing.
Thanks for the workarounds! I've marked this as resolved.
Added subscribers: @Darcvizer, @MichelAnders
Changed status from 'Resolved' to: 'Open'
Somehow missed @brecht's comment, indeed think that would be a nice addition, will do that now.
This issue was referenced by
61cb1a81a8
We can even use depsgraph from context, in fact, should work perfect for 99% of usecases ;)
Just tested it with the daily build (blender-2.80-e4dbfe0a98c1-linux-glibc224-x86_64) and repeatedly ray casting on the bvh now works but if I invoke the operator again (and create a new bvh from the same object) I get a segmentation fault. I'll create a separate bug report that references this one just in case this is not related.
Added subscribers: @Vax456, @Sherm, @capnm, @Joefelix, @Dragon.Studio, @JacquesLucke
