Crash: Vertex snapping with Target: "Active" based on Pivot Point: "3D Cursor" when Active is at 3D Cursor location #57923
Reference: blender/blender#57923
Windows 10
Nvidia GTX 980
Broken: (2.80 Alpha 2 Hash:2c348ebbba9 Date: 2018-11-16)
Blender Crashes when a mesh is scaled with Vertex snapping with the setting Target to Active if the Pivot Point is set to 3D Cursor and the Active vertex is at the same position as the 3D cursor. This happen only if the scaled mesh has more than 15~ verts.
Open Blender
leave the Cube as it is and add a Plane
Move the plane up 2m (Just to see it)
enter the Editmode for the Plane
subdivide it twice (This is important otherwise Blender wil not crash)
select one of the Corner verts
snap 3D cursor to selected
set Pivot point to 3D Cursor
enable Snapping to Vertex with Target to Active
Select the Entire Plane the Active vert is still at the 3D Cursor position
Scale the Plane and snap it to one of the Verts of the default Cube. (or anything else)
CRASH
Added subscriber: @pandrodor
Added subscriber: @lichtwerk
Confirmed, having a look...
Added subscriber: @mont29
For me, blender is freezing here.
Was not the case in 2.79b, but happens in 2.79 master and 2.8. For 2.8 I have checked Debug and Release builds.
Guess this has to do with OMP removal (and its substitution in
43ddf0e9a7
,3c1f3c02c6
)Freeze because it never breaks out of this here .
@mont29: have an idea (I certainly dont...)?
Please ALWAYS add minimal file to reproduce the issue, saves us some time, and ensures we have the correct setup to reproduce the issue!
t57923_vertex_snapping_crash.blend
Using the one above, cannot reproduce on linux. @pandrodor @lichtwerk can you confirm it happens for you with that file?
@lichtwerk are you on windows, if yes, latest win10? If so, could be a different behavior in atomic_cas :/
@mont29: try
#57923.blend
(think the difference is that in my file there is an explicit active vert [white], if I shift-click the corner vert twice [to get it active] in your file, I get the freeze there, too...)
I'm on linux,
gcc version 8.2.1 20181105 (Red Hat 8.2.1-5) (GCC)
if that makes a differenceThanks, can confirm I can reproduce with the active vert.
Eeeh… that’s a rather hairy issue, which originates very far away from where it errors! To summarize:
Easy fix: use memcmp instead of equality operator (but this can be much, much slower...). More 'smart' fix: pointer-cast to uint32_t, and compare those. This should be at least as efficient as float comparison, and bypass the NAN exception.
Will fix the normal accumulator code so that it just skips degenerated geometry. What would be actual correct handling here am not sure at all. Afaikt, official 2.79 already exhibits broken behavior. So will consider this another, unrelated issue. ;)
This issue was referenced by
c9c6433a59
ec851efda9
