Out of the edit mode, the texture space is affected by the modifiers of a mesh. #57985
Reference: blender/blender#57985
Broken: 2.80 Alpha 2
Worked: 2.79.6
Out of edit mode, the Texture Space (me->bb) is behaving like the box bound (ob->bb).
Open the attached file in blender2.79 and blender2.80. Compare the texture space of both cases.
Enter edit mode to see what should be the correct values.
textspace_bug.blend
Added subscriber: @mano-wii
Added subscriber: @mont29
@mont29, it seems you've worked with bound box recently.
Do you know why this happens?
This is already known issue, bbox system is fully broken currently, needs complete rethink. CoW kind of forbids bbox being 'shared' between object and obdata, current situation is a complete mess. :(
Added subscriber: @Sergey
Ugh, this looks complicated…
Basically, in
DRW_draw_render_loop_ex()
,DEG_OBJECT_ITER_FOR_RENDER_ENGINE_BEGIN
returns evaluated Objects (with valid orig_id pointer) which have obdata pointers (mesh, in our case) which are also evaluated ones, but without any link to orig data (id.orig_id pointer is NULL). @Sergey summoning you here, cannot find where that 'final' eval mesh is generated??? Think those should copy over bbox/texspace from their source, but looks like they do not do it...Texspace should only be generated from orig mesh afaik. So either depsgraph gives us evaluated obdata with access to orig one, or whole depsgraph chain ensures to copy over bbox and texco data from initial raw Mesh eval (
BKE_mesh_eval_geometry()
, which unless am mistaken is called on raw, just-copied-from-original mesh eval datablock, does only one thing: compute that bloody bbox).Evaluated mesh is calculated in
BKE_object_handle_data_update()
, with the last step there ofBKE_object_eval_boundbox()
which does copy bounding box back to the original object.Now, this is mainly done for RNA properties and
set()
functions. Draw manager should stay away from original IDs, and simply handle what is given to it. Also, none of the areas shouldn't even touchorig_id
.If you want to copy something from input mesh from pre-modifier state, do so in
mesh_finalize_eval()
. This is up to you to do so, dependency graph can not help here. But i think it is wrong thing to do. Bounding box should always be coherent to the data it corresponds to. As in, if you copy bounding box from source mesh to a result of modifiers you are stepping into situation when re-calculating bounding box for the result mesh will give you different value.To me proper solution here is to explicitly separate bounding box and texture space, and also sanitize things like object's bounding box (which currently will silently fall-back to data's bounding box in certain cases). If such separation is done, you would copy texture space, but keep bounding box in sync with the actual content of the evaluated mesh.
Forgot to mention, quick solution here would be to set texture space for evaluated mesh from original mesh's bounding box and disable auto texture space there.
Did that yesterday actually, was the only way to get back some level of sanity in bbox handling anyway (and to fix some bbox related bugs). ;)
Oh yes, that sounds promising! :D
This issue was referenced by
33cbcd7344
