Crash with keyframing #58117
Closed
opened 2018-11-28 17:34:16 +01:00 by Simone Barbieri · 17 comments
Windows 10 64 bit
Intel Core i7-6700K
32 GB RAM
GTX 1080
Broken: 2.8 2d720f51cd compiled in debug mode
Worked: it works when compiled in release mode
Crash when keyframing a property, deleting the keyframe and inserting the keyframe again.
  • Start blender in debug mode.
  • Select default cube if it not selected.
  • From the property panel, set the keyframe for the location (or any animatable property).
  • Delete the keyframe.
Keyframe the property again.
I've also made a small video showing the issue: https://www.youtube.com/watch?v=AZUsa6vTnYY
**System Information** Windows 10 64 bit Intel Core i7-6700K 32 GB RAM GTX 1080 **Blender Version** Broken: 2.8 2d720f51cd7 compiled in debug mode Worked: it works when compiled in release mode **Short description of error** Crash when keyframing a property, deleting the keyframe and inserting the keyframe again. **Exact steps for others to reproduce the error** - Start blender in debug mode. - Select default cube if it not selected. - From the property panel, set the keyframe for the location (or any animatable property). - Delete the keyframe. # Keyframe the property again. I've also made a small video showing the issue: https://www.youtube.com/watch?v=AZUsa6vTnYY
Added subscriber: @s.barbieri
#58667 was marked as duplicate of this issue
#58688 was marked as duplicate of this issue
Member
Added subscribers: @Sergey, @lichtwerk
Sergey Sharybin was assigned by Philipp Oeser 2018-11-29 10:21:44 +01:00
Member
Confirmed, asserts here:
BLI_assert(DEG::deg_validate_copy_on_write_datablock(&object->id));
1  raise        0x7ffff466853f
2  abort        0x7ffff4652895
3  (anonymous namespace)::deg_iterator_objects_step depsgraph_query_iter.cc 197  0x2f1ad22
4  DEG_iterator_objects_next                        depsgraph_query_iter.cc 285  0x2f1b06e
5  DEG_iterator_objects_begin                       depsgraph_query_iter.cc 252  0x2f1af49
6  DRW_draw_render_loop_ex                          draw_manager.c          1455 0x27fed81
7  DRW_draw_view                                    draw_manager.c          1395 0x27fea87
8  view3d_draw_view                                 view3d_draw.c           1319 0x1d9fef2
@Sergey: could you check on this?
Confirmed, asserts here: BLI_assert(DEG::deg_validate_copy_on_write_datablock(&object->id)); ``` 1 raise 0x7ffff466853f 2 abort 0x7ffff4652895 3 (anonymous namespace)::deg_iterator_objects_step depsgraph_query_iter.cc 197 0x2f1ad22 4 DEG_iterator_objects_next depsgraph_query_iter.cc 285 0x2f1b06e 5 DEG_iterator_objects_begin depsgraph_query_iter.cc 252 0x2f1af49 6 DRW_draw_render_loop_ex draw_manager.c 1455 0x27fed81 7 DRW_draw_view draw_manager.c 1395 0x27fea87 8 view3d_draw_view view3d_draw.c 1319 0x1d9fef2 ``` ``` ``` @Sergey: could you check on this?
Member
Added subscriber: @bdp
Member
Added subscriber: @FrodeLindeijer
Member
Note: I have merged two tasks that do the keyframing on material properties [which is a little bit different from the original report]
In this case we assert elsewhere
BLI_assert((id->tag & LIB_TAG_COPIED_ON_WRITE) == 0);
id is ACMaterialAction
id-> tag is 233472 / 111001000000000000 here [which should be OK?] [which reminds me of #58185]
3   DEG::Depsgraph::add_id_node				depsgraph.cc                    339  0x2f128dd
4   DEG::DepsgraphNodeBuilder::add_id_node		deg_builder_nodes.cc            177  0x2f1fd88
5   DEG::DepsgraphNodeBuilder::add_component_node	deg_builder_nodes.cc            213  0x2f1ff0e
6   DEG::DepsgraphNodeBuilder::add_operation_node(ID *, DEG::eDepsNode_Type, const char *, std::function<void (Depsgraph *)> const&, DEG::eDepsOperation_Code, const char *, int) deg_builder_nodes.cc            253  0x2f20124
7   DEG::DepsgraphNodeBuilder::add_operation_node(ID *, DEG::eDepsNode_Type, std::function<void (Depsgraph *)> const&, DEG::eDepsOperation_Code, const char *, int)               deg_builder_nodes.cc            265  0x2f2019a
8   DEG::DepsgraphNodeBuilder::build_action 			deg_builder_nodes.cc            930  0x2f21ed8
9   DEG::DepsgraphNodeBuilder::build_animdata			deg_builder_nodes.cc            871  0x2f21c70
10  DEG::DepsgraphNodeBuilder::build_material			deg_builder_nodes.cc            1508 0x2f23c72
11  DEG::DepsgraphNodeBuilder::build_object_data_geometry	deg_builder_nodes.cc            1237 0x2f22d5d
12  DEG::DepsgraphNodeBuilder::build_object_data 		deg_builder_nodes.cc            706  0x2f2143b
13  DEG::DepsgraphNodeBuilder::build_object			deg_builder_nodes.cc            627  0x2f2104f
14  DEG::DepsgraphNodeBuilder::build_view_layer			deg_builder_nodes_view_layer.cc 114  0x2f32e7a
15  DEG_graph_build_from_view_layer				depsgraph_build.cc              240  0x2f17063
16  DEG_graph_relations_update 					depsgraph_build.cc              311  0x2f172d1
17  BKE_scene_graph_update_for_newframe				scene.c                         1469 0x2b8b457
18  engine_depsgraph_init					external_engine.c               500  0x22fbda0
19  RE_engine_render						external_engine.c               729  0x22fc7c0
20  do_render_3d 						pipeline.c                      1101 0x230418b
Note: I have merged two tasks that do the keyframing on material properties [which is a little bit different from the original report] In this case we assert elsewhere `BLI_assert((id->tag & LIB_TAG_COPIED_ON_WRITE) == 0);` id is ACMaterialAction id-> tag is 233472 / 111001000000000000 here [which should be OK?] [which reminds me of #58185] ``` 1 raise 0x7ffff466853f 2 abort 0x7ffff4652895 3 DEG::Depsgraph::add_id_node depsgraph.cc 339 0x2f128dd 4 DEG::DepsgraphNodeBuilder::add_id_node deg_builder_nodes.cc 177 0x2f1fd88 5 DEG::DepsgraphNodeBuilder::add_component_node deg_builder_nodes.cc 213 0x2f1ff0e 6 DEG::DepsgraphNodeBuilder::add_operation_node(ID *, DEG::eDepsNode_Type, const char *, std::function<void (Depsgraph *)> const&, DEG::eDepsOperation_Code, const char *, int) deg_builder_nodes.cc 253 0x2f20124 7 DEG::DepsgraphNodeBuilder::add_operation_node(ID *, DEG::eDepsNode_Type, std::function<void (Depsgraph *)> const&, DEG::eDepsOperation_Code, const char *, int) deg_builder_nodes.cc 265 0x2f2019a 8 DEG::DepsgraphNodeBuilder::build_action deg_builder_nodes.cc 930 0x2f21ed8 9 DEG::DepsgraphNodeBuilder::build_animdata deg_builder_nodes.cc 871 0x2f21c70 10 DEG::DepsgraphNodeBuilder::build_material deg_builder_nodes.cc 1508 0x2f23c72 11 DEG::DepsgraphNodeBuilder::build_object_data_geometry deg_builder_nodes.cc 1237 0x2f22d5d 12 DEG::DepsgraphNodeBuilder::build_object_data deg_builder_nodes.cc 706 0x2f2143b 13 DEG::DepsgraphNodeBuilder::build_object deg_builder_nodes.cc 627 0x2f2104f 14 DEG::DepsgraphNodeBuilder::build_view_layer deg_builder_nodes_view_layer.cc 114 0x2f32e7a 15 DEG_graph_build_from_view_layer depsgraph_build.cc 240 0x2f17063 16 DEG_graph_relations_update depsgraph_build.cc 311 0x2f172d1 17 BKE_scene_graph_update_for_newframe scene.c 1469 0x2b8b457 18 engine_depsgraph_init external_engine.c 500 0x22fbda0 19 RE_engine_render external_engine.c 729 0x22fc7c0 20 do_render_3d pipeline.c 1101 0x230418b ```
Philipp Oeser changed title from Crash with keyframing in debug mode to Crash with keyframing 2018-12-04 11:16:24 +01:00
This issue was referenced by c6f47ffa98
This issue was referenced by c6f47ffa98d3fe9c83b2e19b9310a133e842685b
The fix didn't work for me. It is still crashing with the same steps.
Member
Changed status from 'Resolved' to: 'Open'
Member
Yep, still getting both asserts here, too
Member
@Sergey: could you check again?
This issue was referenced by e6141d7b3b
This issue was referenced by e6141d7b3be8520e030de7b9e57264a76aeb588d
Committed few more fixes, hopefully now all usecases are covered :)
Reference: blender/blender#58117
