Stray "forward" and "up" options in 2.8 import addons? #58772
Closed
opened 2018-12-05 08:30:16 +01:00 by Per · 5 comments
Operating system: MacOS High Sierra 10.13.6
Graphics card:
blender2.8, December 04, 00:11:08, 1b6a394d862
Import add-ons in 2.8 seem to show stray Forward and Up options that are not there in 2.79
  1. In Blender 2.79, select File > Import > SVG
  2. Notice that the properties panel in the bottom left corner says No properties
  3. In Blender 2.8, select File > Import > SVG
  4. Notice that the properties panel has Forward and Up options, that probably shouldn't be there?
I also see these stray options when running my fSpy Blender import add-on in 2.8, the operator of which is created like this: https://github.com/stuffmatic/fSpy-Blender/blob/master/fspy_blender/addon.py#L28
**System Information** Operating system: MacOS High Sierra 10.13.6 Graphics card: **Blender Version** blender2.8, December 04, 00:11:08, 1b6a394d862 **Short description of error** Import add-ons in 2.8 seem to show stray `Forward` and `Up` options that are not there in 2.79 **Exact steps for others to reproduce the error** 1. In Blender 2.79, select File > Import > SVG 2. Notice that the properties panel in the bottom left corner says `No properties` 3. In Blender 2.8, select File > Import > SVG 4. Notice that the properties panel has `Forward` and `Up` options, that probably shouldn't be there? I also see these stray options when running my fSpy Blender import add-on in 2.8, the operator of which is created like this: https://github.com/stuffmatic/fSpy-Blender/blob/master/fspy_blender/addon.py#L28
Author
Added subscriber: @stuffmatic
Per changed title from Stray "forward" and "up" options in import addons to Stray "forward" and "up" options in import addons? 2018-12-05 08:30:40 +01:00
Per changed title from Stray "forward" and "up" options in import addons? to Stray "forward" and "up" options in 2.8 import addons? 2018-12-05 08:36:26 +01:00
Added subscriber: @mont29
Bastien Montagne self-assigned this 2018-12-05 10:55:17 +01:00
Very interesting side-effect of using annotations (fields) syntax in dynamic extension of a class definition (through decorator)... Will add detailed technical explanations to https://blender.stackexchange.com/questions/118118/blender-2-8-field-property-declaration-and-dynamic-class-creation
This issue was referenced by blender/blender@74361eebe6
This issue was referenced by blender/blender@74361eebe68c03e73e2b3587988c9d68bd742fe0
Reference: blender/blender-addons#58772
