Blender 2.80 - Removing second Particle System cache causes crash #59958
Closed
opened 2018-12-29 16:41:12 +01:00 by artem ivanov · 11 comments
Operating system: Windows 10
Graphics card: GTX 1070
Broken: 2.80, 7c438e5366, 2018-12-28 23:19, as found on the splash screen (from buildbot)
Changing particle system settings after removing second particle system cache causes crash
Exact steps to reproduce the error
  • Open Blender
  • Load Factory Settings
  • On the default cube: Particle System -> New
  • Particles tab -> Cache -> click on the "+" sign
  • Single left click on the added (and therefore selected) cache entry (see screenshot)
  • Cache -> click on the "-" sign
  • Change Particles tab -> Emission -> Frame Start to any value (or basically change any current particle system setting)
  • Crash with EXCEPTION_ACCESS_VIOLATION.
Alternative steps
  • Open Blender
  • Select the first cache entry
  • Crash with access violation.
Saving file before adding the second cache doesn't affect the crash.
**System Information** Operating system: Windows 10 Graphics card: GTX 1070 **Blender Version** Broken: 2.80, 7c438e5366b2, 2018-12-28 23:19, as found on the splash screen *(from buildbot)* **Short description of error** Changing particle system settings after removing second particle system cache causes crash **Exact steps to reproduce the error** - Open Blender - Load Factory Settings - On the default cube: **Particle System** -> **New** - **Particles** tab -> **Cache** -> click on the "**+**" sign - Single left click on the added (and therefore selected) cache entry (see screenshot) - **Cache** -> click on the "**-**" sign - Change **Particles** tab -> **Emission** -> **Frame Start** to any value (or basically change any current particle system setting) - Crash with `EXCEPTION_ACCESS_VIOLATION`. ![particle_cache.png](https://archive.blender.org/developer/F6107875/particle_cache.png) **Alternative steps** - Open Blender - Load Factory Settings - On the default cube: **Particle System** -> **New** - **Particles** tab -> **Cache** -> click on the "**+**" sign - Select the first cache entry - **Cache** -> click on the "**-**" sign - Change **Particles** tab -> **Emission** -> **Frame Start** to any value (or basically change any current particle system setting) - Crash with access violation. Saving file before adding the second cache doesn't affect the crash.
Author
Added subscriber: @ixd
Added subscriber: @ZedDB
I can't seem to reproduce this on my end. Is this still a problem with the latest blender beta?
Author
@ZedDB Yep. It still crashes for me. Also tested on a different machine running Ubuntu 18.10 x64 - it crashes. More info:
Win 10 (1d908bffdd)
When running blender.exe --debug-all it crashes more rarily (like in 1 of 3 test runs) but here some useful console output (when blender doesn't crash immediately):
Right after 7. Change Particles tab -> Emission -> Frame Start to any value:
Memoryblock cached frames array: double free
and after closing blender:
Error: Not freed memory blocks: 5, total unfreed memory 0.054276 MB
cached frames array len: 252 0000016A1292E308
Pointcache mem len: 176 0000016A133DF0C8
PTCache Data len: 4004 0000016A12FEEAF8
PTCache Data len: 12012 0000016A12E9DDB8
PTCache Data len: 12012 0000016A25CEA718
Blender quit
Ubuntu 18.10 (7f77961f1c)
It doesn't crash after the aforementioned steps, but it does when running with --debug-memory switch.
Output from blender --debug-memory:
Writing: /tmp/blender.crash.txt
Segmentation fault (core dumped)
Content of blender.crash.txt:
# Blender 2.80 (sub 41), Commit date: 2019-01-23 23:36, Hash 7f77961f1c38
bpy.context.space_data.context = 'PARTICLES'  # Property
bpy.ops.object.particle_system_add()  # Operator
bpy.ops.ptcache.add()  # Operator
bpy.context.object.active_index = 1  # Property
bpy.ops.ptcache.remove()  # Operator
bpy.data.particles["ParticleSettings"].count = 1001  # Property
# backtrace
./blender(BLI_system_backtrace+0x1d) [0x1ba3afd]
./blender() [0x1156f99]
/lib/x86_64-linux-gnu/libc.so.6(+0x3ef20) [0x7f67fa1b3f20]
./blender(BKE_ptcache_free_mem+0x28) [0x197c328]
./blender() [0x196c1f5]
./blender(particle_system_update+0x47e) [0x196d6be]
./blender() [0x163884c]
./blender() [0x184ac92]
./blender() [0x184ba01]
./blender(makeDerivedMesh+0x7b) [0x184db2b]
./blender(BKE_object_handle_data_update+0x128) [0x1947568]
./blender(BKE_object_eval_uber_data+0x2e) [0x1947aee]
./blender() [0x1bc1bbc]
./blender() [0x1ba3ea1]
/lib/x86_64-linux-gnu/libpthread.so.0(+0x76db) [0x7f67fb75e6db]
/lib/x86_64-linux-gnu/libc.so.6(clone+0x3f) [0x7f67fa29688f]
Output from blender --debug-all:
# <click to increase particles count>
Memoryblock PTCacheID: double free
# <closing blender>
Error: Not freed memory blocks: 1, total unfreed memory 0.000008 MB
cached frames array len: 4 0x7f4abbb288a8
Blender quit
Also clicking on the freshly added cache item increases reported memory consumption:
(e.g.) zero clicks = 18.7 MB
1 click = 18.8 MB
2 = 19.0 MB
3 = 19.1 MB
4 = 19.3 MB
How to reproduce (click to view gif):
@ZedDB Yep. It still crashes for me. Also tested on a different machine running Ubuntu 18.10 x64 - it crashes. More info: **Win 10 (1d908bffddb4)** When running `blender.exe --debug-all` it crashes more rarily (like in 1 of 3 test runs) but here some useful console output (when blender doesn't crash immediately): Right after ***7. Change Particles tab -> Emission -> Frame Start to any value***: ``` Memoryblock cached frames array: double free ``` and after closing blender: ``` Error: Not freed memory blocks: 5, total unfreed memory 0.054276 MB cached frames array len: 252 0000016A1292E308 Pointcache mem len: 176 0000016A133DF0C8 PTCache Data len: 4004 0000016A12FEEAF8 PTCache Data len: 12012 0000016A12E9DDB8 PTCache Data len: 12012 0000016A25CEA718 Blender quit ``` **Ubuntu 18.10 (7f77961f1c38)** It doesn't crash after the aforementioned steps, but it does when running with `--debug-memory` switch. Output from `blender --debug-memory`: ``` Writing: /tmp/blender.crash.txt Segmentation fault (core dumped) ``` Content of `blender.crash.txt`: ``` # Blender 2.80 (sub 41), Commit date: 2019-01-23 23:36, Hash 7f77961f1c38 bpy.context.space_data.context = 'PARTICLES' # Property bpy.ops.object.particle_system_add() # Operator bpy.ops.ptcache.add() # Operator bpy.context.object.active_index = 1 # Property bpy.ops.ptcache.remove() # Operator bpy.data.particles["ParticleSettings"].count = 1001 # Property # backtrace ./blender(BLI_system_backtrace+0x1d) [0x1ba3afd] ./blender() [0x1156f99] /lib/x86_64-linux-gnu/libc.so.6(+0x3ef20) [0x7f67fa1b3f20] ./blender(BKE_ptcache_free_mem+0x28) [0x197c328] ./blender() [0x196c1f5] ./blender(particle_system_update+0x47e) [0x196d6be] ./blender() [0x163884c] ./blender() [0x184ac92] ./blender() [0x184ba01] ./blender(makeDerivedMesh+0x7b) [0x184db2b] ./blender(BKE_object_handle_data_update+0x128) [0x1947568] ./blender(BKE_object_eval_uber_data+0x2e) [0x1947aee] ./blender() [0x1bc1bbc] ./blender() [0x1ba3ea1] /lib/x86_64-linux-gnu/libpthread.so.0(+0x76db) [0x7f67fb75e6db] /lib/x86_64-linux-gnu/libc.so.6(clone+0x3f) [0x7f67fa29688f] ``` --- Output from `blender --debug-all`: ``` # <click to increase particles count> Memoryblock PTCacheID: double free ... # <closing blender> Error: Not freed memory blocks: 1, total unfreed memory 0.000008 MB cached frames array len: 4 0x7f4abbb288a8 Blender quit ``` --- Also clicking on the freshly added cache item increases reported memory consumption: ``` (e.g.) zero clicks = 18.7 MB 1 click = 18.8 MB 2 = 19.0 MB 3 = 19.1 MB 4 = 19.3 MB ``` --- How to reproduce (click to view gif): ![ptcache.gif](https://archive.blender.org/developer/F6395412/ptcache.gif)
I can reproduce this on 7f77961f1c.
However, I couldn't yesterday and not today either with the latest commit. So I'm guessing this was fixed sometime yesterday (and my build that I tested with was new enough to have this fix in).
Could you see if you can reproduce this again (on both linux and windows) with the current builds from the build bot?
I can reproduce this on 7f77961f1c38. However, I couldn't yesterday and not today either with the latest commit. So I'm guessing this was fixed sometime yesterday (and my build that I tested with was new enough to have this fix in). Could you see if you can reproduce this again (on both linux and windows) with the current builds from the build bot?
Wait, now I'm getting this still on the latest commit :S
Why couldn't I trigger this before I rolled back to the commit you listed...
Ugh, anyways. I can reproduce this on my side with the latest commit.
Wait, now I'm getting this still on the latest commit :S Why couldn't I trigger this before I rolled back to the commit you listed... Ugh, anyways. I can reproduce this on my side with the latest commit.
Bastien Montagne was assigned by Sebastian Parborg 2019-01-25 11:59:02 +01:00
Added subscriber: @mont29
Feel free to reassign if this is not for you @mont29
Just missing a DEG tagging, fix incoming.
This issue was referenced by ea5326df86
This issue was referenced by ea5326df86cba7bb235f623d59cec87bdf9e41b6
Reference: blender/blender#59958
