Errors on OBJ import #60381
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
Reference: blender/blender-addons#60381
Operating system: Windows 10 Pro 64Bit
Graphics card: Intel HD Graphics 530
Broken: 2.80, January 08, 01:07:30 - 91a155833e59
Worked: 2.79b
When I try to import my OBJ model, I get these errors in console:
I removed all "Tr" parameters from corresponding MTL file, but it didn't help much:
Render_Test.zip
Added subscriber: @WannaBe
Added subscribers: @mont29, @lichtwerk
Regarding the
translucency
error: could you share the MTL without 'Tr' being removed?[easier to repro and fix the first issue]
Can confirm the UV mismatch.
@mont29 might know right away? (feel free to throw back at me and I will investigate more...)
[This might not be a bug but a broken OBJ though... where has this been exported from?]
note: this is coming in without errors in 2.79...
UV error comes from the fact that this .obj has two objects named the same ('_1'), I think… will check and fix that (2.79 seems to always fully merge those into a single mesh, while it looks like 2.8 does an hybrid work which generates that mismatch in UV numbers).
original report, the warning itself is nothing wrong, just some unsupported feature. the actual error I'll need unmodified MTL again to investigate.
UV part is fixed, marking as incomplete until we get original MTL to investigate material issue.
Here's a pure MTL file (as exported from a three.js app):
materials_untouched.zip
It seems that missing textures break the import. When I remove all Kd lines, the importer works fine. In 2.79b it wasn't a road-block.
fixed in
5509187b4d
, thanks.
