Single property drivers for properties in the same datablock not evaluated in correct order #61030
Content
Web Development
Reference: studio/blender-studio#61030
Operating system: Ubuntu 18.04
Graphics card: Quadro RTX 6000
Broken: 2.80 33dcf9f
When using single property drivers to access properties on the same datablock, drivers are not evaluated in the correct order. Spring has such a setup for shape keys.
Edit
BKE_object_handle_data_update
to remove the shape key driver evaluation, which should be redundant.In the attached file go one frame back and forth again, cube moves to different location.
shapekey_driver.blend
Added subscriber: @brecht
This issue was referenced by blender/blender@9a7ea778b3
