Bind in Mesh Deform Modifier fails #63252
5 Participants
Reference: blender/blender#63252
Graphics card: GeForce GTX 970/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 382.05
Broken: version: 2.80 (sub 53), branch: blender2.7, commit date: 2019-04-02 19:53, hash:
a813e259d6
Bind in Mesh Deform Modifier fails in recent build.
Open attached .blend file. A Cylinder and Cube is there. The cylinder has Mesh Deform Modifier connected to the cube.
Push bind button, but nothing happens.
I found that an error message is shown in system console, like attached image file, that says,
Cannot get mesh from cage object.
Bind.blend
I tried this .blend file with another build with date 2019-03-30 19:37, and I succeeded the binding.
(So that I guess recent change makes this bug.)
Added subscriber: @popqjp
Added subscribers: @Sergey, @ZedDB
@Sergey when reverting the changes with
64c8d72ef1
you missed the#if 0
statements in MOD_surfacedeform.c and MOD_meshdeform.c .Now it seems like it is not longer possible to bind meshes.
I did some quick tests and just adding back in the commented out code seems to work fine (with additional free checks).
However, I'm unsure if this is the way you want this solved or not.
@ZedDB, those ifdef-ed blocks are to be removed. The Bind operator is to pass evaluated object to the modifier stack, and copy bound data to original.
This issue was referenced by
59f6371a85
Added subscriber: @capnm
Not sure if avoidable – it works now, but "freezes" for several minutes the Blender UI
Binding can take some time to process the math, but several minutes for the file from this report is quite extreme.
Please compare the result on same mesh and cage in 2.7, and if the latest 2.8 is measurably slower make a new report.
f12040e088
The file from OP runs about 4 minutes on one core (3.3 GHz) 100%,
With v2.79 it takes about 10 seconds.
The main problem is that the Window UI isn't updated during the processing time. I was about to kill the process because I thought Blender no longer responds.
While copying the model, I also see this visual glitch. If you select both, the selected cylinder in 2.80 has no outline.
