memory leak - modifiers on curves #65638
8 Participants
Reference: blender/blender#65638
Graphics card: GeForce GTX 1070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 430.64
Broken: version: 2.80 (sub 74), branch: blender2.7, commit date: 2019-06-07 23:24, hash:
749d53effd
Worked: May 26 build works fine. May 31 is broken. I don't have builds in-between.
Adding any modifier to a curve/nurbs and tweaking anything in the modifier or in edit mode will increase memory usage.
Open blend file, press "G" to move and look at the memory.
screw_curve.blend
Or
Add a curve to a new scene, it doesn't matter if it's a bezier, path or NURBS
Add any modifier to this curve
Tweak anything
Added subscriber: @WayAw
memory leak - screw modifier on curvesto memory leak - modifiers on curvesAdded subscriber: @Dspazio
Can confirm. On my older 14 May Build works ok.
Added subscriber: @tomjk
Can reproduce on latest master. Wiggling one end of the default bezier curve, with a subsurf modifier (view subdivs=1) it will leak about 4mb a second. Add some bevel geometry, some extrusions and up the view subsurf level, and it can start haemorrhaging 100's mb a second.
Operating system: Linux-4.15.0-48-generic-x86_64-with-debian-stretch-sid 64 Bits
Added subscribers: @Sergey, @mont29
Will have a look at that one, unless @Sergey beats me to it.
Added subscriber: @EAW
Operating system: Windows-7 64 Bits
Graphics card: 'GeForce GTX 470/PCIe/SSE2NVIDIA Corporation 4.5.0 NVIDIA 391.35'
Broken: Blender-2.80.0-git.cc600de6695a-windows64 May 31- blender-2.80.0-git.749d53effd58-windows64 June 7
Worked:blender-2.80.0-git.d525c76003b3-windows64 May 26th
longer_text_bug_report.blend
I can confirm that this bug also affects text objects. Attached is an example file of some text with a wave modifier. Just open it and hit play. It leaks 1 GB approximately every 270 frames.
system-info.txt
Let me know if I should open a separate bug report
Can reproduce using text objects as well.
Easy steps to reproduce :
If i turn off all modifiers in viewport memory won't leak. When i turn them back on it will happen again.
Text are basically using same code as curves here, so no, no need to open a new report, that is exact same issue. :)
Using chained array modifiers increase memory usage by a lot. Maybe this could give some hint on where relies the problem.
Added subscriber: @antoniov
This is the output running in --debug mode:
This group is repited (more or less equal) as many times as changes in the modifier.
@antoniov this is rather confusing since it mixes direct and indirect leaks. ASAN report is much more interesting as it distinguishes between both, and gives a proper complete backtrace. the root of the issue is that final mesh generated from modifiers evaluation (and stored into
ob->runtime.mesh_eval
) is never freed for cuve objects, for some reasons… Still need to check what happens in depsgraph on that matter.@Sergey this simple patch seems to fix it (just tagging the
mesh_eval
of curve as owned, when we generate one, which makes total sense to me), would rather have your green light on that one though:}
do_makeDispListCurveTypes(
depsgraph, scene, ob, dispbase, for_render, for_orco, &ob->runtime.mesh_eval);
boundbox_displist_object(ob);
Note that the first part of this patch is to address another potential memleak, which I found by reading the code (am not sure in practice it could actually happen with current code paths using
curve_calc_modifiers_post()
, though). But I have the feeling that func could use a bit more love, looks like at some point we had an optimization ensuring we would not generate a tempmodified
mesh in caser_final
was not provided, but now we seem to always generate one, even if we only have deforming modifiers… At least with that minimal patch things should be secure, if not sane.@mont29, makes total sense to me ,good catch! Don't have code handy, but if you verified it properly marks things for curves/texts/surfaces please go ahead and commit.
@Sergey thanks, stealing back then. Yes, am pretty sure this fully covers case reported here, for all curve types.
There are several other issues in another user though (
mesh_new_from_curve_type_object()
/curve_to_mesh_eval_ensure()
couple, used by 'convert to mesh' operator), but those are for other reports (like #65295), will check on those later.This issue was referenced by
6797e80f2e
