.obj import error with mtllib name in quotes - regression from 2.79b #67266
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
Reference: blender/blender-addons#67266
Operating system: Windows 10 64 bit
Graphics card: GeForce GTX 1080 Ti
Broken: 2.80 c2e8e249acf9
Worked: 2.79b f4dc9f9d68b
Blender 2.8 can't import .obj files that contain an mtllib with quotes. While not mentioned in the .obj specification, it seems some software uses quotes when the filename contains blanks. These kind of .obj files could be imported by Blender 2.79b, but the current master branch of 2.8 throws a
FileNotFoundError
.Excerpt of the problematic .obj file:
name with blanks.mtl
name with blanks.obj
Added subscriber: @rjg
Technically this isn't a bug, since Blender follows the spec. However it may still be useful to support this as it was in 2.79b. This issue was originally brought to my intention in this post on Blender StackExchange . The software that created the problematic .obj file was Agisoft Metashape.
Looking at the code of
import_obj.py
from 2.79b it seems that this may not have been an intended feature.If this is of interest, it could be easily fixed by changing line 1151 from:
to something like:
The same issue applies to .mtl files with
map_Kd
and a texture filename in quotes.Added subscriber: @mont29
Indeed, even though that’s not a bug, it does not cost much to support it either… Will commit, thanks for the initial report & investigations.
You're very welcome. Always happy to help and contribute.
Just noticed that this might be a bit more complex to solve in general because
could be a legitimate character in Linux and macOS file names.I would not care much about that… having spaces in filenames is already a bad and annoying habit, but someone putting a quote (single or double) in a file name only deserves what they will get (and a good spanking on top of it ;) ).
This issue was referenced by
05dc8caa35
Can't argue with that. Thank you!
Added subscriber: @darthhawk
The modeler I use doesn't put quotation marks in the OBJ file and Blender has issues importing OBJ files.
I get the following error on trying to import obj files. Other modelers I use don't have this problem.
@darthhawk Please create a new ticket for your issue through Help > Report a Bug in Blender and generate a minimal .obj example file that results in the described problem when imported.
