FBX bug import #70244
Closed
opened 2019-09-25 15:35:26 +02:00 by Pablo Martinez Lopez · 13 comments
Operating system:
Graphics card:
Broken:
(example: 2.79b release)
I can't import correctly Fbx models exported correctly from Daz3d as fbx file.
**System Information** Operating system: Graphics card: **Blender Version** Broken: (example: 2.79b release) (example: 2.80, edbf15d3c044, blender2.8, 2018-11-28, as found on the splash screen) Worked: (optional) **Short description of error** **Exact steps for others to reproduce the error** Based on the default startup or an attached .blend file (as simple as possible). **I can't import correctly Fbx models exported correctly from Daz3d as fbx file.**
Added subscriber: @Estigio97
Member
Added subscriber: @JulienDuroure
Member
Hello,
Please provide a simple fbx file that will show the issue
Hello, Please provide a simple fbx file that will show the issue
I send you the fbx file test. I can open in maya, but not in blender and I need to use blender.Test.fbx
I send you the fbx file test. I can open in maya, but not in blender and I need to use blender.[Test.fbx](https://archive.blender.org/developer/F7774641/Test.fbx)
Member
Removed subscriber: @JulienDuroure
Member
Added subscriber: @lichtwerk
Member
I am getting:
  File "/build_linux/bin/2.81/scripts/addons/io_scene_fbx/__init__.py", line 203, in execute
    return import_fbx.load(self, context, **keywords)
  File "/build_linux/bin/2.81/scripts/addons/io_scene_fbx/import_fbx.py", line 2798, in load
    _(); del _
  File "/build_linux/bin/2.81/scripts/addons/io_scene_fbx/import_fbx.py", line 2795, in _
    root_helper.link_hierarchy(fbx_tmpl, settings, scene)
  File "/build_linux/bin/2.81/scripts/addons/io_scene_fbx/import_fbx.py", line 2293, in link_hierarchy
    child.link_hierarchy(fbx_tmpl, settings, scene)
  File "/build_linux/bin/2.81/scripts/addons/io_scene_fbx/import_fbx.py", line 2249, in link_hierarchy
    (mmat, amat) = mesh.armature_setup[self]
KeyError: Genesis8Female
I am getting: ``` Traceback (most recent call last): File "/build_linux/bin/2.81/scripts/addons/io_scene_fbx/__init__.py", line 203, in execute return import_fbx.load(self, context, **keywords) File "/build_linux/bin/2.81/scripts/addons/io_scene_fbx/import_fbx.py", line 2798, in load _(); del _ File "/build_linux/bin/2.81/scripts/addons/io_scene_fbx/import_fbx.py", line 2795, in _ root_helper.link_hierarchy(fbx_tmpl, settings, scene) File "/build_linux/bin/2.81/scripts/addons/io_scene_fbx/import_fbx.py", line 2293, in link_hierarchy child.link_hierarchy(fbx_tmpl, settings, scene) File "/build_linux/bin/2.81/scripts/addons/io_scene_fbx/import_fbx.py", line 2249, in link_hierarchy (mmat, amat) = mesh.armature_setup[self] KeyError: Genesis8Female location: <unknown location>:-1 ```
I receive the same error message
Member
Note: despite the fact the armature wont be correctly set up (error above), I still get a mesh coming in (Genesis8Female.Shape)
There seems to be something wrong with that, too (get a crash entering editmode on this one).
I have to call:
bpy.data.meshes['Genesis8Female'].validate_material_indices()
to correct this.
Note: despite the fact the armature wont be correctly set up (error above), I still get a mesh coming in (`Genesis8Female.Shape`) There seems to be something wrong with that, too (get a crash entering editmode on this one). I have to call: `bpy.data.meshes['Genesis8Female'].validate_material_indices()` to correct this.
This issue was referenced by 6eb9c11fe0
This issue was referenced by 6eb9c11fe04454601065d6e93029622b88eb69c8
Added subscriber: @mont29
Bastien Montagne self-assigned this 2019-09-25 17:46:17 +02:00
Will fix the crash (issue related to sub-armature children of main one), but please note that importing such complex rig is doggy at best in Blender currently… You'll have to reset the pose at the very least.
5 Participants
Reference: blender/blender-addons#70244
