Ctrl+Shift+Click on a node does't work if the node is already selected (Link Viewer, Node Wrangler) #70581
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
14 Participants
Reference: blender/blender-addons#70581
Operating system: Arch Linux
Graphics card: gtx 1060
Broken: 2.81, 4707f1982ddb
Node wrangler (emission viewer): Ctrl+Shift+Click on a node is supposed to cycle thru all of its outputs to the emission viewer node. But it doesn't work with the latest alpha.
Bultin: Ctrl+Shift+Click on a node should link to a viewer, this is only working if the node is not selected already
Added subscriber: @Tyler-Foo
blender/blender#70758 was marked as duplicate of this issue
blender/blender#70748 was marked as duplicate of this issue
Node wrangler (emission viewer), Ctrl+Shift+Click on a node does't cycle thru all of itto Node wrangler (emission viewer), Ctrl+Shift+Click on a node does't cycle thru all of its outputsAdded subscriber: @YegorSmirnov
Yes, found that too. It doesn't cycle through the outputs because ctrl_shift_click doesn't work on selected node at all. If you take an unconnected node, select it and ctrl_shift_click it - nothing happens.
Added subscriber: @kosblend
Added subscriber: @VladimirKunyansky
Can confirm on 40a55be82cf5
Doesn't cycle through, doesn't connect active nodes.
But hotkey 'O' is working with active nodes.
Added subscriber: @MichaelHermann
Added subscriber: @lichtwerk
Confirmed, checking...
Added subscriber: @brecht
Caused by blender/blender@5f51e78172 / blender/blender@be2cd4bb53
Note this does not only break the Addon, but e.g. the native
Link Viewer
etc.CC @brecht
Marking as High prio since it is a regression.
Node wrangler (emission viewer), Ctrl+Shift+Click on a node does't cycle thru all of its outputsto Ctrl+Shift+Click on a node does't work if thenode is already selected (Link Viewer, Node Wrangler)Ctrl+Shift+Click on a node does't work if thenode is already selected (Link Viewer, Node Wrangler)to Ctrl+Shift+Click on a node does't work if the node is already selected (Link Viewer, Node Wrangler)Added subscriber: @BartekMoniewski
Added subscriber: @EAW
Added subscriber: @B_Engstler
Added subscriber: @leiserfg
Added subscribers: @GabrielMoro, @MarcinTwarowski
Added subscriber: @jlw3d
This issue was referenced by blender/blender@80fe0ac7ff
Added subscriber: @peterling
Added subscriber: @ArtyomSobolev
