Ocean modifier crashes blender. #71040
6 Participants
Reference: blender/blender#71040
Graphics card: GeForce RTX 2070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 431.86
CPU: Ryzen 5 2600
Memory: 16 Gb.
Broken: version: 2.80 (sub 75), branch: master, commit date: 2019-07-29 14:47, hash:
f6cb5f5449
I found this problem in 2.80 stable version and also in current 2.81 build.
Starting new file. Creating plane. Adding Ocean Modifier. Increasing resolution to 32. Blender crashes.
Sometimes it gives the chance to change resolution, but it also crushes when you click Bake Ocean with Generate Normals, Generate Foam(Coverage 2.0), Start 1, End 1.
Added subscriber: @just_own3d
Added subscriber: @dgsantana
Can confirm. Crash on freeing task for ocean_compute_displacement_y. Only happens if you enter directly a high resolution. If increase incremental to 32, the error doesn't occur. Also after that, you can enter any value without crashing.
It can also happen calling ocean_compute_displacement_x and probably ocean_compute_displacement_z.
Added subscriber: @MarcinTwarowski
Looks like a duplicate of #58983 ?
Yup it seems. And it may be true that the problem is a conflict between the blender tasks/threads and the internal fftw threads, in which they don't wait on each other. I'm diving a little deeper. But the patch we are discussing should at least solve the threading problem, and avoid the crash. But the Ocean modifier needs more work, because it gets "resimulated" in situations where this shouldn't happen, like moving the object that as no animation.
Added subscriber: @Jeroen-Bakker
Unable to reproduce in B2.80-B2.82 on linux. As others have reproduce this one. I will set it to known issue.
Added subscriber: @mont29
Changed status from 'Confirmed' to: 'Needs User Info'
Cannot reproduce any of this here either with latest master on linux...
Also, backend of our multi-tasking code was switched to TBB recently (and fix proposed in D6121 should "not work" since it should be a no-op change), so if someone on windows could try to reconfirm this issue still happen for them? Thanks.
Tested on
Changing resolution to 32 does not crash. However following these steps:
At resolution 32 did crash Blender.
However, tested on:
Simply changing resolution to 32 does crash to desktop.
Changed status from 'Needs User Info' to: 'Needs Developer To Reproduce'
Hrrrmmmm..... I still cannot reproduce, but I have found some discrepancy in threaded code logic in ocean simulation...
Can you please try that patch and see whether you can still reproduce the crash?
P1395: Potential fix for #71040
Changed status from 'Needs Developer To Reproduce' to: 'Needs User Info'
I'm afraid I won't be much help here. Someone else needs to test it.
Hrrrmmmm Actually that patch is pure rubbish,
BLI_task_parallel_range()
is by design blocking, so guaranteed to be finished before we start adding more tasks to the pool......OK, so potential new candidate (aka next shot in the dark):
P1401: Fix for ocean thread pool crash #71040 and #58983
Changed status from 'Needs User Info' to: 'Resolved'
solved for now, final solution will be in the 2.90 lib update round.
