Issue trying to weight paint if object has mirror+armature. #71213
6 Participants
Reference: blender/blender#71213
Graphics card: GeForce GTX 1070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 430.86
Broken: version: 2.82 (sub 1), branch: master, commit date: 2019-10-28 21:19, hash:
2dab4393b0
Broken: hash: 2.81
95f020c853d6
, build date: 2019-10-14, 00:11:29Worked:
f88022b96f3a
build date: 28/08/2019, 01:48Short description of error
If an object has an armature its normal to move bones to see the effect and paint on the deform mesh, this always worked.
In the lastest builds it seems that adding a mirror modifier after the armature modifier mess up how the object its read and the stroke doesn't register that the mesh its deformed.
Mirror afects vertex paint, error.blend
1-Open the blend file
(it was tested using default factory settings too but it was created with my normal set up, you may see some addons active, as i said i also tested in a default settings)
2-try to paint in the blue circle(1), nothing should happen.
3-try painting in the red square(2) it should paint, as if the cylinder wasn't deformed.
4-Reload the .blend file
5-delete the mirror modifier and repeat step 2 and 3
Added subscriber: @NahuelBelich
#72633 was marked as duplicate of this issue
#71804 was marked as duplicate of this issue
Added subscribers: @Jeroen-Bakker, @mano-wii
Can I confirm.
This is probably due to using a
mesh_eval_deform
instead ofmesh_eval_final
somewhere.@Jeroen-Bakker, is this your area?
Added subscriber: @Likkez-2
Can confirm, happens while using Mask modifier too. Please fix, super annoying.
Added subscriber: @Mets
Perhaps the same root cause as #68352.
Would be awesome if these bugs got some love, it's been a pain in the butt having to disable mirror and mask modifiers every time I go into weight paint mode. Note that I also need to change shading options when going into weight paint mode ever since 2.80. This means going into or out of weight paint mode now takes 6-8 actions (and my script to automate these actions causes crashes).
Yea, also the wireframe checkbox in weight paint does nothing now but that's a whole other issue.
Added subscriber: @Semple
Added subscribers: @icappiello, @angavrilov
Mask can be moved after the Armature modifier, but mirror is a problem. This bug basically ignores all modifier starting with the first non-pure-deform modifier in the stack.
This issue was referenced by
893c29c15c
f1ac64921b
Since there fortunately was a specific 'worked' and 'broken' version pair in this report, I found which specific change broke it and reverted it.
Now it just skips those Mirror and Mask modifiers like before, which is not ideal, but better than this behavior.
Added subscribers: @Lumpis_Wartimus, @JacquesLucke
Thanks a lot for the fix on this! An improvement I wish for, is if the modifiers that are not being considered by painting, could just be disabled entirely while in weight paint mode.
Currently, for the mirror modifier, we just can't paint on the mirrored part, which is not a big deal. But if there is a Mask modifier before the Armature modifier, we can paint on the masked out parts, which is very prone to making mistakes. Although I feel like it's not technically a bug, since the code is probably doing what it was intended to do, but it is an unfortunate side-effect. Should I open a fresh report?
