view stops rotating #71612
5 Participants
Reference: blender/blender#71612
Operating system: Darwin-18.7.0-x86_64-i386-64bit 64 Bits
Graphics card: Intel Iris OpenGL Engine Intel Inc. 4.1 INTEL-12.10.12
Broken: version: 2.80 (sub 75), branch: master, commit date: 2019-07-29 14:47, hash:
f6cb5f5449
if I press (shift, control, option, lock caps, fn, or command) my view lock up and only zooms in and out.
rocky.blend
Added subscriber: @Egorsurfer08
#68963 was marked as duplicate of this issue
#69637 was marked as duplicate of this issue
#71221 was marked as duplicate of this issue
view stops rotateto view stops rotatinghi I followed the steps Philipp Oeser (lichtwerk) advised:
Please try the latest daily build: https://builder.blender.org/download/
Go to File → Defaults → Load Factory Settings and then load your file to see if you still can reproduce this issue.
The problem is still there
Added subscriber: @AdamPreisler
What you can try to do is create a new file and append everything from this through File -> Append if that solves the issue.
Or you might have activated the zooming option maybe on the top right and it somehow stuck? Not sure what could be causing this.
For me the error isn't there anyway, I was able to navigate freely:
hi,
I created two system-info files, one when everything works properly and the second one when shift blocks the view. Also while doing that and saving files i realised that shift actually blocks the mouse in "right button hold” mode because I couldn't even choose the folder to save the second file. I went through all the possible options of reloading and resetting settings, but it didn’t help. I’m using MacBook Pro with a touchpad. I also checked my general key settings and couldn’t find anything that might interfere.
thank you I really appreciate your help
system-info2.txt
problem.mov
system-info1.txt
Added subscriber: @lichtwerk
why are we not sticking to a single report here?
(anyways... will merge the other one in, since this has a bit more info...)
Added subscriber: @StephenSwaney
#71635 (Problems with Shift Key on Catalina after 4 or 5 hours of modelling.) might be related?
another possibly related #70482 (Middle mouse turns from rotate to zoom )
Just asking: are you using a Wacom?
removing Wacom applications was mentioned as solution in #70482 (Middle mouse turns from rotate to zoom )
waiting for the answer regarding wacom...
This issue was referenced by
3a344a61e8
8cb55f8d16
Added subscribers: @LubomirIngeli, @mont29, @DenisBelov, @Sushi, @ideasman42
