Crash : Malformed .bmp files lead to crash. #71960
10 Participants
Reference: blender/blender#71960
There is no bounds checking in
source\blender\imbuf\intern\bmp.c
leading to out of bound access if the bmp file is malformed.repro:
c:\Users\[username]\Documents\
Note: The problem exists in the 16bpp (rgb565) codepath as well but i had nothing that could write that format.
Note2: The header checks also do not respect the buffer bounds, i didn't have time to make to make a crashing bmp, but whoever will work on this will have to fix that as well.
note3: the crashy bmp files are created by taking a regular bmp file and truncating it to about half their size, leading to a correct header, but not enough image data in the file.
[Original report]
Operating system: Windows 10 Pro, Version 1903, Build: 18362.476
Graphics card: Nvidia GTX 980 TI Driver 441.20
Broken: 2.181 release
On fresh install of 2.81, startup with default project.
Select the Shader tab and Blender crashes with:
found bundled python: C:\Program Files\Blender Foundation\Blender 2.81\2.81\python
Error : EXCEPTION_ACCESS_VIOLATION
Address : 0x00007FF63621A4B0
Module : C:\Program Files\Blender Foundation\Blender 2.81\blender.exe
Added subscriber: @Ed-H
#83324 was marked as duplicate of this issue
#68164 was marked as duplicate of this issue
blender_debug_output.txt
blender_system_info.txt
Had the same issue with 2.80
Added subscriber: @mano-wii
This is strange, it seems that the graphics driver is one of the latest.
https://www.geforce.com/drivers?nvid=nv-int-bnnr-96776#cid=internal_en-us_banner_gtx_900_series_upgrade
But we do not have much information to know what is happening.
Try after loading Factory Settings. (
File -> Defaults -> Load Factory Settings
)Did loading the factory settings have any effect?
No
Added subscriber: @iss
Changed status from 'Needs Developer To Reproduce' to: 'Needs User Info'
Is this still an issue with latest build? https://builder.blender.org/download/
Added subscribers: @ronsn, @robbott
Still fails with 2.82:
Build info:
Also tested with 2.83:
Still fails.
Build info:
Changed status from 'Needs User Info' to: 'Needs Developer To Reproduce'
Still happening with 'blender-2.83-cdfaddbb1d42-windows64'blender_system_info.txt
Is there anything else I can do on my end?
This comment was removed by @Ed-H
Just tested with 2.90 May 18th alpha. Still crashes on Shader tab.
Added subscriber: @Delenn97
Was a fix ever found for this? Or can I nolonger use blender
I noticed that if I open this project and click the Shader tab Blender does not crash. So maybe there is some initialization or un-initialized value somewhere(?).
Detailing-Project-File.zip
Added subscriber: @LazyDodo
Can you try a daily 2.90? When it crashes it should with a bit of luck write out a crash report that may help tracking this down.
Still crashed at 2.90 6/1/2020 build. Here are the debug / info files.
Running NVIDIA drivers 446.14 on 980 TI.
blender.crash.txt
Also tried "factory startup" cmd still no luck.
Seems to crash while trying to generate a thumbnail for a
.bmp
file, is there any chance you could run ProcessMonitor and see what the last.bmp
file was that blender read? and then do 2 two things.Changed status from 'Needs Developer To Reproduce' to: 'Needs User Info'
Actually i made some bad .bmp files and can repro easily, there is NO bounds checking whatsoever in the bmp loader.
That fixed it.
The file was called "hokie.bmp" and it was not a valid .BMP file. Must have been corrupted. I cannot open it with any other graphics. tool. This file was in the "My Documents" folder; which it looks like Blender goes through and reads all the media there. I probably could change that directory in the upper left frame to point to a more specific place for Blender related media. I have attached problem file here.
Thank you for your analysis.
Not sure if you want it, but i repaired the file by just padding it with white pixels
Error : EXCEPTION_ACCESS_VIOLATION when selecting the Shader tab on new projectto Crash : Malformed .bmp files lead to crash.I was actually able to open it with microsoft Code(??!) I had to open a valid BMP file first though.
This was probably created by a pinball table editor. I've deleted it, thanks.
Images & Movies isn't a project really, so I guess I will add #vfx_video
Or we can update query https://developer.blender.org/maniphest/query/J_RaaSzk5wr0/
Added subscribers: @Kealinit, @rjg
Just wanted to point out that, the original cause of the Shader Editor crash is because Blender would scan the "My Documents" folder for image files when the user selected the Shader tab; and in my case hit a bad .BMP file in the process.
Added subscriber: @Sergey
We should at least add a pixel data size check in the the bmp implementation.
This issue was referenced by
7c864388fc
5b08cbae51
