Can't save file because of too many open files #73862
5 Participants
Reference: blender/blender#73862
Operating system: Fedora Linux 31
Graphics card: Nvidia GTX 760
Broken: 2.82
Worked: 2.81
After trying to get fluid sim working (and failing, no liquid is showing up) I can't save the file anymore. It says too many open files.
Trying to bake a fluid sim and then save the file.
Added subscriber: @bloody_albatross
sign3d_scotch_rotate_b282.blend
Also blender crashes on exit now:
Blender quit
Segmentation fault (Speicherabzug geschrieben)
Added subscriber: @ankitm
https://docs.blender.org/manual/en/latest/physics/fluid/type/domain/cache.html#cache This mentions Domain to be the type where you've set Flow. Can you add how you were trying to bake it ?
I don't understand this sentence. To me it reads like you mean I should have set the small circle to Domain, but that makes no sense. (English isn't my native language.)
I just where clicking the "Bake Data" button under Settings.
I don't see bake data when red box is "Flow". It comes up only when it is "Domain".
But it crashes two seconds after I click bake data. The folder it makes named "cache_fluid" has two folders "config" and "data". Both are empty.
I am not an expert in this process, so I might be wrong.
The circle defines the inflow. The cube around everything is the domain. The domain will become the actual fluid and has the bake button. What exactly is your question?
Added subscriber: @ideasman42
From these steps I can redo an error,
Scotch.Domain
Fluid -> Settings
pressFree Data
Bake Data
button which replacedFree Data
.While that's a bug which should be fixed, I'm surprised the limitation is hit so quickly, enough to cause a crash (I would have to run this over 500 times to hit the limit).
Can you confirm that you're doing the same steps listed above?
Yes, basically. But I also changed settings back and forth, trying to get fluid sim to work (I can't get it to show anything -> pretty sure that is a(nother) bug). But yes, I baked, freed, baked again, freed, baked, paused, continued, etc. Also tried to bake the mesh and particles at some point.
This issue was referenced by
edc7bd5f3f
60890ccf9d
Changed status from 'Needs User Info' to: 'Resolved'
Added subscriber: @Funnybob
I'm having the same issue with 2,83a. At one point the sim jus t stop working. I trued to save and I get the same error message.
