Image Texture unpredictable behavior in Workbench renderer when duplicating node #74713
Reference: blender/blender#74713
Operating system: Linux-4.18.0-25-generic-x86_64-with-debian-buster-sid 64 Bits
Graphics card: GeForce GTX 1060 6GB/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 390.116
Broken: version: 2.83 (sub 6), branch: master, commit date: 2020-03-03 18:38, hash:
31aefdeec5
Duplicating an Image Texture node causes the displayed image texture to go all white in Workbench renderer
see attached .blend demo
Demo video:
image_texture_issue.mp4
Source image:
.blend file:
image_texture_issue.blend
Added subscriber: @clepsydrae
#75427 was marked as duplicate of this issue
Added subscribers: @Jeroen-Bakker, @mano-wii
I can confirm.
I'm not sure which criteria Workbenck uses to choose the texture node. (I imagined it would be the last selected texture).
Manual informs that it chooses the active texture:
https://docs.blender.org/manual/en/latest/render/workbench/color.html#color
If this is the case, it seems that defining the active texture is somewhat unpredictable.
@Jeroen-Bakker, bug, known issue or works as designed?
I analyzed the code and this is really a bug involving
depsgraph
and"COW"
.Added subscriber: @Omer-Almadani
Added subscriber: @Sergey
@mano-wii, What are the details, what is going wrong?
Following the video you should have two texture nodes.
Check the
nodeSetActive
function and see which node receives theNODE_ACTIVE_TEXTURE
flag when selecting it.It is always the last selected node texture.
Now notice the
nodeGetActiveTexture
function that is called by the Workbench.The node name with the
NODE_ACTIVE_TEXTURE
flag is another.I haven't investigated this problem for a while, but I suspect that when comparing the IDs you realize that the difference is that one is the COW and the other is the original.
There is no ID comparison or difference is happening in the dependency graph. The only issue I do see which is related to dependency graph is that removing texture from the node (clicking on the X) does not tag relations for update. I would not call it a dependency graph problem since the issue is not in the graph: someone need to call
DEG_relations_tag_update()
in the proper place. But this is separate issue (which must be fixed, but which is not the root cause of this bug).Now, to isolate whether something is caused by missing relations update tag or ID update tag: save and reload. If bug does not happen after save and reload it might be a missing update tag (either in the dependency graph, or in other area which might be doing caching). Here it seems save and reload after removing the texture does not solve the problem. So you can be quite sure this bug is not related to dependency graph update/evaluaiton.
Now when you mention
nodeSetActive()
. This function does check for a proper texture ID, so clicking on a node which does not have texture it will not become active. But this function is not called when you remove the texture from node:nodeSetActive()
is not called when you click on "X".What happens is: duplicating node makes the new one active. Deleting texture from this node does not affect the node active state, so you are ending up with a situation when active node has no texture ID.
If the viewport is designed to use active texture in workbench mode, then this actually seems a proper behavior: the node is active and it does not have texture.
We can try changing active texture when you removed texture from node, but think this will cause more confusion than solve issues. Imagine situation:
The last point can be addressed by doing
if ((node->flag & NODE_ACTIVE) && node->id != NULL) {
innodeGetActiveTexture
, but it does not solve the confusion that after clicking on "X" some other random texture will be used in the viewport.The problem that I considered here was not to do with node without texture (by pressing the X).
You can add another texture to the other node if you prefer.
The problem I see is that the active texture is not the last one selected (as seen in 2.79)
image_texture_issue_2_79.blend
(When I mentioned comparing IDs I mean to manually compare the values of "same nodes" in the IDE)
So it's nothing to do with duplication at all then, and the issue is in the selection operator, which does modifications without telling anyone about it.
P1375: Fix for #74713
This issue was referenced by
27e3361eb5
4d677ec90d
