LLVM ERROR: Error while trying to spill SGPR4_SGPR5 from class SReg_64: Cannot scavenge register without an emergency spill slot! #75895
8 Participants
Reference: blender/blender#75895
Operating system: Linux-5.3.0-46-generic-x86_64-with-Ubuntu-19.10-eoan 64 Bits
Graphics card: AMD Radeon RX 5700 XT (NAVI10, DRM 3.33.0, 5.3.0-46-generic, LLVM 9.0.0) X.Org 4.5 (Core Profile) Mesa 19.2.8
Graphics card driver: amdgpu-pro-20.10-1048554-ubuntu-18.04
Broken: version: 2.90 (sub 0), branch: master, commit date: 2020-04-18 16:48, hash:
1f1520a045
Worked: -
Blender crashes during opencl kernel compilation
Using the supplied blend file, render using GPU (OpenCL)
Added subscriber: @RL
Added subscriber: @iss
Can you try to strip .blend file down as much as possible? It is possible, that you will end up with very small file that wouldn't contain any data you can't share.
Also please click on File > Defaults > Load Fatctory Setings and let us know if this helps.
I've managed to recreate a scene that produces the crash on my system. Note that it's not specific to this material; any material I append or link from my external material library will produce a crash on render.
This was ran with blender --factory-startup.
TEST-GPU-RENDER.blend
This haven't crashed in my case, but render result was quite wild
Or should I make library and append it to example file and add material from lib to cube?
Are you using the same GPU?
No
Graphics card: Radeon RX550/550 Series ATI Technologies Inc. 4.5.13587 Core Profile Context 20.4.1 26.20.15029.20013
Added subscriber: @secureworkstation
I can confirm the issue. It started to happen once I updated the AMDGPU-PRO OpenCL driver from 19.50 to 20.10.
My software is similar to @RL's. The same Ubuntu driver, Blender master. Hardware - 5700 XT too. As a temporary measure, I recommend downgrading to 19.50... even though it crashes a lot for me.
I run it under Fedora though. I repackage the Ubuntu driver: https://github.com/secureworkstation/rpm-amdgpu-pro-opencl
@iss I think the issue is exclusive to this particular setup, at least the GPU.
@secureworkstation I'm kinda glad I'm not the only one having problems with this GPU. I've had numerous problems with it since.
With the 19.50 driver, the render just hangs indefinitely, see #74262
Yes - it happens to hang quite randomly and then I can't reboot Blender (seems like some Linux kernel issue) and I must hard reboot the whole machine. I found some workaround - it's possible to render (ALMOST always hang-free) in text mode (as in, Ctrl+Alt+F2, not XTerm) using:
$ blender --background test.blend --render-output out --render-frame 1
Sometimes it kills my Wayland session, but I learned to live with it. I hoped that with the 20.10 driver it works better, but I guess we need some fix to the Blender kernels to acomodate the stack upgrades, but unfortunately that's outside of my expertise.
Added subscriber: @brecht
This error message seems to indicate a bug in the AMD OpenCL driver, an internal compiler error. We may be able to work around it, or get AMD to fix it.
I will try to install this driver version and reproduce.
I tested the 20.10 a bit further. For rendering it works well - as in, the kernel compilation works well, but under a Wayland session it hangs - the same as with 19.50, it only crashes when I change the shading to Viewport Shading. I assume the kernels are compiled a bit differently in those cases.
For reference, 20.10-1048554 works fine for final and viewport render here with a WX 7100 on Ubuntu 18.04. Installed using:
Added subscriber: @Jeroen-Bakker
@brecht Well, our installations do differ somehow. Let's find out what causes those issues.
@secureworkstation - upstream Linux AMDKFD driver, unclean installation, Ubuntu driver, RDNA card, PAL driver
@RL - AMD packaged AMDKFD driver (dkms-amdgpu), clean installation, Ubuntu driver, RDNA card, PAL driver
@brecht - AMD packaged AMDKFD driver (dkms-amdgpu), clean installation, Ubuntu driver, GCN 4g card, ORCA (legacy) driver
Please fix if I am wrong. But if I'm right, then it seems that the issue persists at least across users the of the PAL driver, at most across users of the RDNA generation cards.
This is how we can ensure that we use the PAL driver (which is for Vega10+, and WX 7100 is Polaris10):
What I have installed currently is:
I don't think I'm using the dkms version. I installed my driver with
amdgpu-pro-install --opencl=pal --headless --no-dkms
I've also upgraded my system to Ubuntu 20.04, though I don't think that's essential to the equation here. Attaching system info and clinfo output.
system-info.txt
clinfo.txt
I guess the difference is in the HSAIL and LC intermediate languages. Only Navi hardware uses LC.
I'm not sure it's safe to install using
--no-dkms
though, maybe that leads to a mismatch between the kernel module and the rest of the driver.Installing with dkms breaks my whole display stack, (Unable to login to desktop; black screen with blinking white underscore) which is understandable because neither Ubuntu 20.04 nor 19.10 is supported by the current driver, hence the
--no-dkms
What I find weird is if you look at my original report, I was able to use OpenCL (
--no-dkms
) without problems using Ubuntu 19.10 with theamdgpu-pro-19.30-838629-ubuntu-18.04
andamdgpu-pro-19.50-967956
drivers, until the USD changes. So it might not be entirely the driver's fault.Unable to reproduce using Ubuntu 18.04.4 HWE + amdgpu-pro-20.10
system-info.txt
When upgrading I made sure that I completely removed the previous amdgpu-pro driver. Did a clean boot. and installed the OpenCL drivers only of the amdgpu-pro-20.10.
amdgpu-pro-install --headless --opencl=PAL
I used the open source drivers for display.
@Jeroen-Bakker, can you post
clinfo
output? Did you check both F12 render and viewport render?clinfo.txt I tested with f12 render, but yes it breaks during viewport rendering.
Can we also test on Ubuntu 20.04 LTS? I understand it's not currently supported by the driver, it's just so we have an apple-to-apple comparison.
The way I did it is to edit
/etc/os-release
and changeVERSION_ID="20.04"
toVERSION_ID="18.04"
so the installer won't complain that the OS is not supported.I isolated the part that fails to compile. You could check if it works with P1357: (An Untitled Masterwork)
applied.
Successful renders with both F12 and viewport! Simply genius! Thank you!
This issue was referenced by blender/cycles@c96dfd93f8
6121c28501
Changed status from 'Needs User Info' to: 'Resolved'
Everything works with the latest master. Thank you!
Furthermore, it seems that since Linux kernel 5.6.7-300.fc32.x86_64 the freezes (unrelated to this bug) are gone.
Added subscriber: @alexbarcelo
This comment was removed by @alexbarcelo
Added subscriber: @Arvind_Ravichandran
The issue is only with amdgpu-pro drivers <> NAVI architecture card (Radeon Rx 5000 series) combination. F12 render crashes during kernel compile only if the scene has volumetrics. Entering viewport rendering mode always crashes. Have tested my card with amdgpu 20.10 with the latest stable build (2.83.2) of blender and it still has the issue.
